Sci525
Member
Hi everyone,
I overhauled my 1971 AU-101 yesterday. New electrolytic caps, small transistors, and power supply diodes (transistor substitutions below). Sounded good for 20 minutes before the right channel went out. Turned it off and back on and the right channel was on for 5 min before going out again and for good. Left channel is fine and both fuses are good. Its clean and while the factory soldering looks rough, it ran fine for many years.
Transistor substitutions
CDC-8000 -> KSC2690 AYS
CDC-9000 -> KSA1013 YTA
2SA640 -> ZTX795 A
This amp does not have a variable bias resistor. I took some quick voltage measurements across the speaker terminals and both hovered in the 3-10 mV range, however I did not remeasure after warm up. In circuit measurements of transistors after failure show that the 2SC1060 output transistors all read the same across channels, however the KSC2690, KSA1013 and ZTX795 read differently on the right and left channel. In circuit measurements of both channel's transistors varied from my understanding of out of circuit measurements so I'm not certain how to interpret the values.
My un-educated guess is that poor bias caused the right channel to overheat and I'll need to replace these transistors as well as replace the fixed bias resistor (reading 85 ohms) with a 1/4W 200 ohm trimmer.
Can I get any expert advice? I only have one KSC2690 left so I'd really like to get this right on the next go.
Thanks!
Joe
2SA640 -> ZTX795 A
Thanks!
Joe
