P2201 : thinking PS Recap
Discussion in 'Yamaha' started by dondoucette, Jan 18, 2015.
  1. dondoucette
    dondoucette Too Many Projects Subscriber
    552
    Regina, Saskatchewan Canada
    P2201 : thinking PS Recap Some Help/Info needed.
    So I was thinking of picking up 4 22,000uf 100v capacitors to recap my two P2201's
    At this very moment I can't open either one to measure the physical dimensions of the originals. I don't think mistakenly buying a replacement capacitor that is physically bigger than the originals is likely however I don't want to make that mistake.
    Also I was thinking if I find 27,000uf that will more closely match the dimensions of the originals I might opt for the slightly larger capacitor.
    So it might be a stretch but has anyone here done a recap and can share the measurements of the OE capacitors.
    Thanks in advance.
    Don
    Ahem... Hey mister, could you spare a pc5002m?
  2. dondoucette
    552
    Well I opened one of my amplifiers up.
    Physical size of those capacitors is 2.5" diameter by 4.5" tall
    Should be able to find a suitable replacement to fit in that space.
  3. tyeeslayer
    tyeeslayer Super Member
    3,143
    Abbotsford, British Columbia
    Probably a good idea especially if they were ever "used hard and put away wet".
    Or spent time in a rack.
  4. dondoucette
    552
    Yeah the newest addition to the collection looks like it had a rough life and probably seen more than one drink spilled on it.
  5. dondoucette
    552
    Has anybody ever heard of EPCOS Capacitors
    Supposed to be good for 12,000 hrs @ 85c and I can get them for $50 each plus shipping.
  6. belgianbrain
    belgianbrain Super Member
    1,273
    Greater Toronto Area, Canada
    I think that's what I used in my M2.
    If memory serves, it was on the only brand readily available.
  7. tyeeslayer
    3,143
    Looks good, should be an easy swap-out too.
  8. dondoucette
    552
  9. dondoucette
    552
    Guess I'll order the EPCOS capacitors.
  10. ConradH
    ConradH Addicted Member
    8,082
    Canandaigua, NY
    This is a case where measurements make sense, unless you're made of money. There's an excellent chance that there's nothing wrong with those caps. The Epcos "12,000" hour part is also a 2000 hour part by the standard tests everybody normally uses. Or, to put it another way, all caps that don't have some initial manufacturing defect will go way more than 12,000 hours when derated. The odds of other caps being "tired" are probably higher than the PS.
  11. dondoucette
    552
    No doubt. A future endeavour to be sure.
  12. dondoucette
    552
    Caps are ordered.
    Pics of swap out when they arrive.
    Then I will go through the amps and make a list of all the other capacitors needed.
    Also I'm working on a project with a buddy of mine to improve the appearance of the old Yammies. Stay tuned.
  13. dondoucette
    552
    Gave one of my P2201's some TLC today.
    So while I was rooting around inside I saw this...
    I don't recall seeing anything like this except around a flyback transformer in old CRT TV's. What the heck?
    Left channel was 17mv and right was 19mv, both adjusted to 10mv and done.
    Hooked it back up and it sounds a bit better but I still have a little hum on the left channel.
    Next up are all the other electrolytics in the amp then I'll move on to the rest of the capacitors.
    But first I need to track down the source of this hum...
    So just for interests sake I tested the old caps on my Sencore LC77 and the were not in good shape. ESR was 9ish ohms on one and over 6 on the other, dielectric absorbtion and leakage current were also bad, it was time.
  14. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,435
    Fort Dodge, Iowa
    Most likely tar and nicotine with a side of dust.
  15. dondoucette
    552
    Yeah probably
  16. EvanF
    EvanF AK Member
    290
    Kirkwood, Missouri
    Ever track down the source of hum? I have a P2200 that has had a full recap as well with no solution to the hum. I checked the solder joints too.
  17. miklemke
    miklemke AK Subscriber Subscriber
    865
    Is it a grounding problem?
  18. dondoucette
    552
    My hum was resolved by replacing the balance of the electrolytics. Fantastically quiet amps when working well. If you short the inputs and turn the volume all the way down does your amp still hum, does it only hum when you turn up the volume.
