cortico
Just checked the bias setting on this power amp. Both channels were set at 10mv across emitter resistors, the service manual calls out to set it at 20mv (+-2mv), no load, after the amp is running for 1/2 hour and then readjust after it's stabilized.
I proceeded as per manual, noticed the following when powering the unit on with the voltmeter leads attached across emitter resistors:
Right channel idle current climbs up from 0mv to set value +-17.5mv
Left channel idle current climbs up to about 22mv and than comes back to +- 17.5mv, looks like it's drawing more current at startup.
Is this a reason to be concerned?
Thanks
Thanks
