I have an M&K HP-80 passive crossover (high pass 80 Hz filter). The early model came set from the factory as version A, B or C, which would match the input impedance of your power amp. Later models came with a 3-position switch, so you could switch between A, B or C, depending on the amp you're using.
Mine is an early version C, which can be seen in the quote from the manual and pic below as being optimized for 47K nominal. This worked great with my previous amp, but my new amp has an input impedance of 11 Kohms, which means I need version A now. So, I'd like to modify mine to be version A.
> "SETTING THE "AMP INPUT IMPEDANCE" SWITCH
On the HP-80 back panel is a three-position switch, marked A, B, and C. Set this switch to match the input impedance of your power amp. Consult your amplifier's manual to find the input impedance of the power amplifier section only. Most amps and receivers use the C position. Consult your dealer or the amplifier's manufacturer if you can't find this spec. If you are unable to identify the impedance, set the switch to the C position.
Optimized for / Use for input impedances
A position - 10 Kohms / 10K ohms to 19.9 Kohms
B position - 22 Kohms / 20K ohms to 29.9 Kohms
C position - 47 Kohms / 30K ohms and over" <
This crossover has 2 resistors per channel, which I'm guessing correspond to the input Z of the power amp. I'm not sure if they're in parallel or series though. I'll attach a pic of the PCB, which shows that the resistors go from ground to the output RCA's.
R1 = 34.7K ohms
R2 = 20K ohms
*Could I change these resistors and make this a version A? Or, is the inductor an influence on the impedance as well? I hope with the explanation and pics, this can be figured out. I really appreciate any help, thanks in advance!
R1 = 34.7K ohms
R2 = 20K ohms
