rulerboyz said:I don't believe I've noticed any significant difference between using different types of Y cable. The ideal of course would be to have a card with RCA out jacks. The quality of your soundcard is going to play a critical role in the quality you will get.
dew042 said:If you have a Best Buy close -- their generic y cable in the mp3 section is $15 at most and its a very well made cable. Dynex is the brand. Well shielded and well built.
Frankly the sound output on that sound card leaves a little to be desired. I could suggest a very good analog card for about $30 shipped if you are interested.
dew.
dew042 said:Is this a new card? I hate it when they reuse names... my mistake.
Back in the day Turtle Beach had another Montego card that was nothing special, in fact is was less than nothing special. I was a rabid TB Santa Cruz fan for many, many years. I share your comtempt for Creative, although I was recently forced to buy a Creative product to ouput from my laptop.
So, Mitsuman - what do you think of the sound of this card? I am not familiar with the Cmedia chipset it has onboard.
Decius - This Chaintech card is a great budget card - if you manually turn on the hi sample rate option it has one good DAC (it will output out of the 9/10 channel on the back) and does 2 channel analog out very well. If you use digital output its good as well. Otherise the other 7 DACs are junk: http://www.newegg.com/Product/Product.asp?Item=N82E16829120103
dew.
nashbap said:Dew 042:
I am considering purchasing the Chaintech AV710 as you mention. My primary use would be for converting LP's to burn to CD's so does this have a good analog to digital converter in your opinion? Thanks.
salred said:I've done a few transfers to CD so far, and I've been pleased. While I've done the transfers mostly to play in my car, a few test spins on my main system have sounded pretty good, and for $25 I think its a bargain. Give it a try!
Other parts of my workflow:
TT -- > PC: RIPVinyl (http://www.ripvinyl.com/)
Declicking: ClickRepair (http://wwwmaths.anu.edu.au/~briand/sound/)
Split tracks, etc: Audacity (http://audacity.sourceforge.net/) [Free!]
Burning: The software that came with my PC
Steve A.
