With the 900 DRS I currently have two sets of 8 ohm speakers hooked up. If both sets are played at the same time, would I engage the 4 ohm switch on the front or leave it in 8 ohm?
View attachment 1087236 With the 900 DRS I currently have two sets of 8 ohm speakers hooked up. If both sets are played at the same time, would I engage the 4 ohm switch on the front or leave it in 8 ohm?
Switch Swampy, The Amp will "See" The load change. Some Pro Amps have the switch. Just touch top of amp and judge heat. Some Carver amps will heat up at 4ohms. Forget about anything lower.
