Philips CD Player belt: Gone with the wind! Help!
Discussion in 'Digital Sources' started by chadbang, Mar 2, 2017.
  1. chadbang
    chadbang Well-Known Member
    777
    Far From Home
    Today I had the worst thing happen. I need to replace the belt on the Philips CDM-2 laser assembly. Today, I opened the machine and removed the belt which drives the tray. I place it into an an envelope and carefully tuck it in my into shirt pocket. My plan was to go to Frys and try to find a similar size belt (that failing, Home Depot or Lowes for a comparable size thin O-ring). No sooner than I start driving that I pull my driving glass out of my pocket and little envelope with the belt flies out my window! I couldn't believe it. I carefully tucked that into a small envelope and purposefully placed it in my pocket and out the window it goes! I was fuming!
    Now, tonight, I just wasted 2 1/2 hours on the web trying to find out what size that belt was. NOBODY has this information posted: What is the size of the tray drive belt on the CDM-2 Philips laser? Help! Does anyone know! I may end up having to buy a multipack of size from China (one month wait) to try and figure out the right size and then rebuy a better one! Oh the pain. I even know the part number and it's no help. 482235820116 ANTRIEBSRIEMEN
    Please, does anyone know the dimensions of the belt on these units?
  2. E.Auer
    E.Auer Super Member
    1,587
    Lobster Pot
    Measure the path of the belt?
    Eric
  3. shelly_d
    shelly_d Not An Audiophool
    5,999
    Alameda CA
    Advice from a website selling replacement belts:
    CD / DVD /cassette drive: Use a piece of string or wire to measure the total distance round the band drive path. Then deduct approximately 10 to 15% to allow the correct drive tension.
    Here is the site:
    http://www.cassettedrivebelts.com/
    Google is your friend.
    Shelly_D
  4. chadbang
    777
    Far From Home
    So simple. I'll give it a try. thanks!
  5. shelly_d
    5,999
    Alameda CA
    You are very welcome.
  6. chadbang
    777
    Far From Home
    Looks like 5.6" IC belt (measured six inches exactly, but you subtract 5-7%. for tension and 5.6" is a very common size.) I did manage to ferret out after three hours on the web that the diameter of the square belt is .125" although some like to use a .165" diameter belt. I found one right in the middle of those sizes and bought it. Will report my success.
  7. dosmalo
    dosmalo T-Totaled Subscriber
    3,818
    The Cult of Personality
    From the sound of your OP, you should've maybe bought two.
