I recently posted about a nice Technics SA-600 receiver that I picked up and that I had adjusted the bias because it was a bit high. A couple of people reached out asking how to adjust the bias, so this post is about how I went about it.
I started tinkering on amps and receivers as a total novice about 5 years ago and greatly appreciated all the knowledge and help on this board. To be honest, it was all very daunting and I imagine others may feel the same. Here's a minor attempt at paying it forward. Those more knowledgeable are welcome to critique or add to what I have posted below.
DISCLAIMERS: (1) I am not a trained technician, but I've done a lot of reading and have recapped and serviced quite a few units. (2) Be careful. An accidental slip with a probe or screwdriver can and will mess up either you and/or your receiver.
Items needed:
1) Service manual (download available at HiFi Engine). This is the most important page for setting the bias, but the full manual also tells the best way to open up the unit, etc.
2) Digital multimeter with probes (not clips), set to measure DC. See note in photo about use of clips vs. probes.
3) Flat head screwdriver.
The key points on the receiver -- where to measure and where to adjust.
The arrows on the photo below are an example for DMM probe location for the right channel.
The locations of VR601 (right channel) and VR602 (left channel) to adjust the bias voltage.
The process:
1) Start with the unit turned off. The input should be set to AUX, volume to minimum, tone controls flat, loudness disengaged, no speakers attached.
2) Insert the DMM probes in the locations indicated above and in the photos below. NOTE: my probes didn't reach too far down along the sides of the resistors, but be careful, because it is possible for the probe tips to touch the output transistors located below.
3) Power on the receiver and DMM (either order is fine). Wait at least 5 minutes for everything to stabilize.
4) Measure and adjust the DC voltage to 8 mV by adjusting VR601 for the right channel (you could do the left channel first if you want, doesn't matter).
5) Power down the receiver, move the probes to the resistor on the top of the heat sink of the other channel and repeat steps 3 and 4.
Another look a little zoomed out...
The follow-up:
After adjusting the bias, I checked the DC offset at the speaker terminals. It should read less than ~10mV for each channel. See this massive thread for all about measuring DC offset: http://audiokarma.org/forums/index.php?threads/amplifier-distortion-dc-offset-and-you.5634/
Lastly, here she is unopened. I happen to think she's quite pretty.
Items needed:
The process:
The follow-up:
