Garven
I'm currently running a 2M Black. While it's not bad, it doesn't handle surface noise very well and seems really particular about pressing quality as well (some LPs sound magical, others not so much). I'm thinking of alternate choices I could make all in roughly the $300 range. I have the following cartridge bodies already available: AT150MLX, OM Super, 2M Bronze/Black
Turntable/phono stage
- Current: Pro-Ject Xpression II with 8.6 arm, upgraded with speedbox and acrylic platter
- Future: RP6, Clearaudio Concept, SL1200, or even PLX-1000. No comments necessary from the Hanpinphobes
- In both cases, running through a Lehmann Black Cube
- Good tracking of sibilants
- Detailed sound but but balanced frequency response with solid bass, musical midrange, and clear highs
- Low surface noise
- AT150MLX stylus
- DL-301 MKII
- OM40 stylus
- 2M Blue stylus
(I could go for the Bronze but it's close enough that I might as well stay with the Black). - Alternates (AT-F7 for example). I had an OC9MLII and found it a good tracker but a bit metallic and brash.
