If the LPGear is any good, was also pondering upgrading to the D1200 stylus, but it might be overkill for my table. That's listed for transcription turntables and tracks a whole bunch lighter than the D625. Same price as the OEM D625 ... They also have the D750 clone in the middle of the range.
(I'd be interested in what Pickering had in mind with the whole "transcription table" thing. Seems to me they haven't built those since the '30s to play 16" disks ...)
Just to confuse the issue ... JACO makes a shibata tip (D4555Q) that fits and is supposed to be an excellent upgrade. Hmmmmmm ... I do have a lot of quad disks laying about. I've got an Audio Technica AT15S that I usually use for that, but I recently replaced that with (you guessed it) an LPGear shibata that I'm not all that happy with.
Hence the dilemma ...
Just reread this post and now I'm kinda sorta leaning towards the JACO shibata for the XV15 ... kill a couple birds with one stone maybe?
Might help to know my tables ... Primary is a Mitsubishi DP-EC10 direct drive and my backup is a Technics SL-23A servo belt. I usually run around a gram tracking force, and the D1200 is listed for 3/4 - 1 1/2 grams, so that's definitely in play ...
Pickering used to try and simplify things by saying which types of turntables cartridges were suitable for. You wouldn’t necessarily put a top of the line cartridge on a cheap BSR or Garrard automatic record changer, which is more what Pickering were trying to guard against with their advice. Their use of the term “transcription” really dated back to earlier eras. However, it’s not really relevant these days – most turntables with tonearms which have adjustable counterweights, and oil-damped cueing, will be suitable for their best cartridges, and the replacement styli for them.
Both of your turntables will be suitable for all of the XV-15 styli available, right up to the top of the line elliptical, the D1200E. There was a later, even better stylus, the stereohedron (Pickering’s name for their version of the Shibata) D1800S, which took over from the D1200E as Pickering’s best XV-15 stylus. The ones to look at buying include the D625E or D750E, which are 0.3x0.7 ellipticals, or the D1200E, which is a thinner (better) 0.2x0.7 elliptical, or best of all, the D1800S stereohedron (or aftermarket Shibata replacement). They are the only ones you should buy, although there are also some cheaper models which fit, but in the words of Pickering, really aren’t suitable for your turntables (they deserve better).
You need to be very careful about buying them from either Jico or LPGear, not because they don’t sell good styli, but with the Pickering models, they get confused between Pickering’s XSV/XUV series, which are moving magnet cartridges, and their XV-15 models, which are moving iron models. I suspect the reason LPGear have it wrong is that they’ve copied Jico – or maybe it’s the other way around!
Other styli, including the model you quoted (D4555Q) are NOT suitable for the XV-15 cartridge, and reflect Jico/LPGear’s confusion between Pickering’s MM and MI cartridge models. They don’t know what they are doing! MM styli won’t work properly in your MI cartridge, so just ignore their list of models that are suitable for the XV-15 – many are not.
The following styli fit Pickering's MM cartridge models, and NOT the XV-15: D4500Q, D3000, D4555Q and XV15/4500AME (oh, goodness – I know there’s a language barrier, but all they’re doing is confusing people with models that have NEVER existed).:screwy: So ignore all of those ones, which according to Jico, fit the XV-15 – they don’t, as they fit Pickering’s XSV/XUV/LZS cartridges, which are MM models. They also even get the (MI) V15 models in there, which are quite different from the later XV-15 models they confuse them with – grrrr!:bash:
