I finally procured, tested, painted, and installed the replacement output transformer for this unit, and I am starting to re-cap it. First oddball thing that came up was in the power supply, specifically C1A & C1B (2 halves of a can capacitor). On the attached schematic (from a SAMS I bought), the A half is 80 mfd and the B half is 40 mfd (see schematic section attached). On my unit, and on the doner unit my OPT came from, these are reversed. I am guessing that this is a schematic error but I would like a sanity check. Does it make sense to have the 40 mfd "first in line" so to speak, then the 80 mfd next?
Next question. My amp is full of "Imp" capacitors that I plan to replace. The donor unit has a mix of "Imp" and some other brand. Sometimes there will be an Imp in one channel and the red/white brand in the other. Same values & voltage ratings in both amp. Any idea why that might be (other than pricing at the time)?
Thanks.
Thanks.
