Pioneer 1000A rectifer diode question
Discussion in 'Pioneer Audio' started by gkargreen, Sep 15, 2018.
  1. gkargreen
    gkargreen Active Member
    482
    Fairfax, VA
    Hi, I am working on this set, lots of recapping, and one question I have regards the caps across the voltage doubler diodes, I assume they are snubbers for the switching noise in the diodes, correct? If I am going to replace the diodes with UF diodes, would I still need to include those caps? Thanks
  2. avionic
    45,588
    Fort Dodge, Iowa
    I would.
    merlynski and Hyperion like this.
  3. Watthour
    What unit is this? A typical voltage doubler MUST have caps to charge between half-cycles to float the potential up to the desired peaks.
  4. avionic
    45,588
    Fort Dodge, Iowa
    I'm thinking he is referring to the bridged rectifier.
  5. Hyperion
    49,276
    Hertfordshire, UK
    'Pioneer' 1000A :idea:
    avionic likes this.
  6. Watthour
    You are probably correct, which is the reason for the inquiry as to what the unit actually is.
  7. avionic
    45,588
    Fort Dodge, Iowa
    :dunno::dunno:
    Hyperion likes this.
  8. Hyperion
    49,276
    Hertfordshire, UK
    :dunno: :D
  9. larryderouin
    22,051
    Glen Burnie Md.
    It's a Sansui 1000A. And there are paralleled caps on the rectifier diodes to the 1st doubler cap. As avionic stated and I agree with him, put them on.
