Copy and paste it into a spreadsheet and save it in either ".xls" or "csv" format
The part number for Mouser electronics is the column beginning with either 647- for the caps or 512- for the transistors.
Once you create an account, the Mouser site will allow you to import the file as a bill of materials right into your shopping cart.
The big power supply filter caps and the caps/transistors for the tuner are not part of the BOM.
Expect a few discrepancies between the list and the caps in your unit.
The actual caps installed apparently vary a bit over a production run.
Huge time saver, though, using the list.
The little parts are about 30 bucks at Mouser and the big caps, maybe 20 each. Seems a good premium to save you some work of actually looking at your unit and compiling the cap list (available here in ak) and placing an order.
