Pioneer Cassette Player CT-F-7171
Discussion in 'Tape' started by StanleyM, Feb 11, 2018.
  1. StanleyM
    StanleyM New Member
    26
    N.C.
    I picked up aPioneer Cassette Deck, model CT-F7171 along with some other units for a 100 bucks including a Dual 1229Q Turntable. The belts are shot on the deck so I took it apart and used some rubber bands just to see if it would play. Now it keeps blowing the motor fuse, I could get it to play and FF but that is it. Did I put it back together wrong? Any help is welcomed!!
  2. inductor
    inductor Super Member
    1,519
    uk
    never had a problem with fuse blowing with a 7171, must be something unusual, dont remember there being a fuse to the motor ?
  3. StanleyM
    StanleyM New Member
    26
    N.C.
    If you open it up there is a bank of 4 fuses, there is a 1 amp, 2 ea. .500 amp and the one for the motor is .800 or .850 amps. As soon as I cut the power on it blows. I checked the fuse to ground and it was OL. Thanks for replying I would really like to get this unit up and running.
  4. inductor
    1,519
    uk
    thats not shown in the service manual i have, anyhoo, motor is probably goosed, did you mean it blows when you switch it off ?, had another look at the manual and yes it was lurking furtively, (me mistook)
  5. StanleyM
    StanleyM New Member
    26
    N.C.
    No blows fuse when power is turned on. I don't believe the motor gets power due the fuse blowing before I can push Play FF or Rewind.
  6. inductor
    1,519
    uk
    check the diodes and capacitor for shorts, and\or disconnect the motor and see if it still blows
  7. StanleyM
    StanleyM New Member
    26
    N.C.
    on the power supply?
  8. StanleyM
    StanleyM New Member
    26
    N.C.
    Ok I will let you know my findings, maybe I will get lucky and see the obvious problem. Thanks for your help!!
  9. inductor
    1,519
    uk
    yes the psu
  10. StanleyM
    StanleyM New Member
    26
    N.C.
    OK took a look at this circuit looks like it could be a diode or cap now I just have to locate this circuit.
  11. inductor
    1,519
    uk
    the psu is the small board to the back of the chassis if i remember correct
  12. StanleyM
    StanleyM New Member
    26
    N.C.
    Ok, thanks!! I will check it out when I get home this afternoon. Thanks again for all your help!! I have several old Pioneer Receiver's, have you ever repaired any?
  13. inductor
    1,519
    uk
    have i ? lost count but then i wasnt counting
  14. StanleyM
    StanleyM New Member
    26
    N.C.
    Good one!! So I found the short in the player, when I installed rubber bands on the spindles I put the play switch on the wrong side of the switch actuator shorting out the switch. I picked the player unit it up put on the other side and walla I turned the power on and the fuse did not blow even pushed play and the motor turned. Now I have a bigger issue I removed the dolby processor board while hunting for he psu. Once you told me where to look I was securing the dolby board back down and cracked a glass resistor I guess is what it is. I took a close up pic of it and was going to post but my phone died. It is located on the right channel. I tried to find the number for the component it but no luck. I am gonna get my loop out and look at the board and see if I can see a number for the component in question. I know I have thanked you for your help but I would like to thank you again. Answering peoples questions takes time so I am grateful.
  15. StanleyM
    StanleyM New Member
    26
    N.C.
    OK got a pic of the component that I broke this pic is from the left side, I would imagine the right is exactly the same Dolby Processor
  16. inductor
    1,519
    uk
    thats a diode
  17. StanleyM
    StanleyM New Member
    26
    N.C.
    Thanks, never seen one like that before, I should be able to put a meter across read the value and order one? Or does it have to be glass for a reason?
  18. inductor
    1,519
    uk
    if you can 'measure' the diode values ? eh, might get more idea in your other post
  19. inductor
    1,519
    uk
    a 1n4148 should do, are you sure its that one the picture looks like a germanium signal diode
  20. StanleyM
    StanleyM New Member
    26
    N.C.
    It could be, I have tried to trace it down to where It's location is. I have tried to look for some type of writing on it. I took the broke one out that was on the right channel then took the left one out on the left channel they are the same but no numbers or writing on them.
