Ikura
Hello, have a CT-F750 that does not work. All the lights and buttons function fine but the fw, rw, and play do not. I thought maybe the belts needed to be changed out so I opened it up. When I turned it on to see which belt(s) were slipping I noticed nothing was turning, not even a hum of the motor. Lights all lit up but no other movement in the unit.
This is my first tape deck I am trying to get working as I have the amplifier, tuner, and TT that pair with it.
Would anyone be able to tell me if I am just out of luck or if there is something I should look into when it seems like the motor is not spinning any of the gears.
Thank you...
Thank you...
