Pioneer help for noob...
Discussion in 'Pioneer Audio' started by arcspark, Apr 29, 2018.
  1. arcspark
    arcspark Member
    70
    Afternoon, would anyone like to take a crack at helpin me figure out whats goin on with this integrated 6500 ii? Picked it up cheap, cleaned it up and out, deoxed the controls but the right channel has loads of static with cd plugged into aux... speaker a and a and b....left channel crystal clear....crystal....but roll the balance control and it goes bad right now.....ive got to believe i should be able test something and get some values...any thoughts, thanks, arc
  2. zebulon1
    5,056
    Las Vegas Nevada
    It sounds like more Deoxit to me.
    Loudness selector is one of the key switches.
    All the controls have the signal running through them regardless of the position. They all must be cleaned to evaluate the amp.
  3. arcspark
    arcspark Member
    70
    Hey thanks zeb.....will keep at it for awhile. Will focus on loudness switch too....also looking down on the board it seems like maybe caps leaked or something as there is a dried hardened tan fluid especially on the left by three large caps and on the right by the single large one there...alot of stain on the ones left side....any thoughts appreciated....arc
  4. zebulon1
    5,056
    Las Vegas Nevada
    Its probably the glue Pioneer used to mount the caps. It gets rubbery and can be removed safely with a dull exacto blade.
  5. arcspark
    arcspark Member
    70
    Thank you...arc
  6. KingBubba
    10,166
    Brooksville, Fl.
    If that amp has High and Low filter switches, they are also a good place to check Try cycling the switches on and off 50 times, turn on the amp and see if that helped. Just for future reference, you only need to check A. A and B are coming from the same point in the amp.
  7. arcspark
    arcspark Member
    70
    Ok thanks to all, well it doesnt appear to be switch related.....i have deoxed to the point of waste and no real change...flipped switches hundreds of times....so now what baby steps should be done?... ive read a post about maybe bad transistors but i dont know....any thoughts to at least diagnose what to possibly fix....thanks for listening, arc
  8. petehall347
    28,342
    uk.. the middle bit
    unplug input rca cables . see if still bad . try different input selector position . also try every switch and control . see what is common to all inputs that affects it mostly .
    kvining likes this.
  9. kvining
    kvining Active Member
    284
    Planet Houston
    Typical. Balance knob always seems crankier, probably because they sit in one position for years at a time and then when someone finally rotates it, it spreads all that oxidation crap around. I soak it good and stand the box up on the short side and rotate it every hour or so along with working the dial. Sometimes you have to hit it two or three times over the course of a couple days. Remove the bottom cover and squirt it in from there too. Deoxit Gold seems to work better. Sooner or later it'll break lose.
  10. kvining
    284
    Planet Houston
    Good advice. I had one where the cap on the input jack was covered with some sort of slimy goo that was preventing contact, cleaned each one with a qtip and contact cleaner and it came to life.
  11. arcspark
    arcspark Member
    70
    Ok stay tuned....thanks
  12. arcspark
    arcspark Member
    70
    Ok cleaning hasnt helped...been told to maybe use some freeze spray to possibly isolate a problem...is there a certain type and are there rules to follow? Thanks arc
  13. arcspark
    arcspark Member
    70
    Bump it.... thanks
  14. Watthour
    Try the CD input on one of the TAPE inputs to determine if the problem still exists. The ONLY difference between the AUX and TAPE inputs is the function switch.
    Also test it with the LOUDNESS switch on and off to detect any differences.
  15. Bob
    Bob AK Subscriber Subscriber
    2,565
    West coast
    isolate the problem, try CDP into different high-level inputs (Aux, FM), then try CDP into
    tape monitors (1,2) which are after the inputs and selectors, etc.
    you can then isolate the problem to the preamp/line stage, or the power amp stage.
    download the service manual, for the schematic, and if you're game, jumper the
    switches (anything on the front) and see if it's a switch problem. do use insulated
    probes that clip onto the test points, don't use them manually - one slip and some
    thing gets destroyed.
    since you have one good channel, you can trace the sound and determine where it
    goes bad.
    there's so much to do before replacing transistors. could be cold/bad/flakey solder
    joints. my static problems were with old/bad caps. (you've identified that with one
    good channel it's not the core portion of the power supply). etc.
  16. arcspark
    arcspark Member
    70
    Ok thanks for the reply..will try to apply this and see where it goes...appreciate it everybody.....arc
  17. arcspark
    arcspark Member
    70
    Ok, its been awhile but here goes .....facts and questions....after cleaning, recleaning every switch multiple times its prob not corrosion, so following what bob, watthour said i tried every input but phono and nothing changes..still bad distorsion, static on right channel. On to something else so when you said jumper switches do you mean to temp bypass to remove them one at a time from the circuit?? If so can you example that for me ?? As the original post stated...NOOB.. i understand the idea of a jumper but want to be sure to do it right...Also... i tested dc bias tonite and right side is 50.6, left is 37.2, fyi....thank you, arc
  18. petehall347
    28,342
    uk.. the middle bit
    dont forget the mic jack .it has switched contacts and if something was plugged in there recently it may have caused a bad connection .
    saying that it should only affect phono .
  19. petehall347
    28,342
    uk.. the middle bit
    i missed that earlier ..
  20. UncleBingo
    1,675
    Iirc , that amp has 2sa798 transistors in there. Get them gone asap.
