Pioneer PL-44FS tone arm belt
Discussion in 'Pioneer Audio' started by MadeMine, Aug 11, 2017.
  1. MadeMine
    MadeMine Active Member
    188
    Has anyone ever replaced the tone arm drive motor belt on a Pioneer PL-44FS turntable. Check out my post over on turntables no one can help. I can't get the motor base and tone arm base to line up with the cogs correctly to work. A factory service manual is needed here I think, does any one have one?.
  2. Balifly
    Balifly Listening Subscriber
    19,045
    Vancouver, B.C., Canada
  3. MadeMine
    188
    Thanks Balifly, I already have the SM. What I need is the factory service manual that shows the tonearm drive motor base and the tonearm base re-assembly.
  4. redk9258
    redk9258 Super Member
    1,446
    Illinois, close to St. Louis.
    Did you look at it? The title would imply that it is the factory service manual.
  5. MadeMine
    188
    Yes I read the entire service manual, It does not go into any detail about changing the tonearm drive motor belt and reassembly alignment of the tonearm motor base and tonearm base. I have seen some factory service manuals on other Pioneer equipment.
  6. redk9258
    1,446
    I never knew there was 2 kinds of service manuals... unless an aftermarket company (SAMS) put it out. I thought if Pioneer published it, then it IS the factory service manual. :dunno:
  7. MadeMine
    188
    Thanks redk9258 I appreciate the input. But, has anyone ever replaced the tone arm drive motor belt on a Pioneer PL-44FS turntable. I am not having any luck reassembling and aligning the cogs and gears correctly. I already downloaded the SM from VE and it does not cover reassembly of the tonearm base.
