Pioneer PL-50 alignment
Discussion in 'Turntables' started by keithpgdrb, Jul 8, 2010.
  1. keithpgdrb
    keithpgdrb Super Member
    2,221
    Bolingbrook, IL
    Does anyone have a recommendation on what method/protractor I should use on a Pioneer PL-50 turntable/S arm/Denon 110 cart. I've been having a horrible time dealing with mis-tracking and what sounds like un-even volume. Unless of course most albums are mixed favoring the right.
    example - was listening to van morrison's tupelo honey album, and his vocals distort all over the place on some tracks. really irritating. anyone want to have a cartridge set up party? I'll buy beer and pizza.
  2. catman
    catman Addicted Member
    7,611
    G'day mate, any good two point overhang protractor properly set up should work fine. I prefer to use Baerwald alignment which should work well with the Pioneer's tonearm.
    This page has some good general guidelines in regard to the proper use of a typical two point overhang protractor. http://www.mds975.co.uk/Content/vinyl07.html
    Suitable two point protractors can be downloaded from the alignment protractors link at the Vinyl Engine website (up near the top of the front page) or sometimes suitable two point overhang protractors are supplied free with cartridges, e.g the Shure M97xE. Regards, Felix aka catman.
  3. BrocLuno
    BrocLuno Lunatic Member
    11,661
    Napa County, Calif
    If the TT and arm are stock, I believe the cartridge should be square in the headshell and positioned so the stylus tip is 49mm from the back of the collar. Have you downloaded the manual from Vinylengine.com? Any Pioneer TT owners manual should do unless the 50 is unique?
  4. catman
    7,611
    G'day all, yes the 'shortcut' value is a lot easier than using a protractor! Perhaps Howard can give us the difinitive answer? Regards, Felix aka catman.
  5. drknstrmyknight
    drknstrmyknight Addicted Member
    5,564
    Mount Clemens, MI
    Have you leveled the platter?
  6. keithpgdrb
    2,221
    Bolingbrook, IL
    Hey guys,
    the pioneer is fitted with a red tab as an overhang index. I've used that, centered it exactly on the guide, but I'm still not happy. I pulled out the "enjoy the music" two point baerwald (i believe) protractor, and my cart was not even close. so my question is, should I go ahead with the baerwald adjustment, or the stevenson? I feel like I read that pioneers like the stevenson.. I could be very wrong though.
    Yes, the table is level. or at least as level as I can get it.
    I would also love to hear from Howard! clearly a guru.
  7. finnbow
    finnbow The Dude Abides
    11,985
    MoCo, MD
    As you say and per the manual available on Vinylengine, the PL-50 is provided with an overhang index stand. I would trust this more than any other method, in terms of ease and accuracy for setting overhang.
    That said, this turntable has both anti-skate and lateral balance adjustment. The lateral balance adjustment procedure is sorta interesting. Lifting the back of the turntable twenty degrees for adjustment, etc. This is done before anti-skate adjustment. I would ensure that these are set up IAW the manual and while you're at it, check azimuth and VTA.
  8. Frank Sol
    Frank Sol Addicted Member
    7,790
    SoCal
    Personally I use the Baerwald on all vintage S-arm Pioneers
  9. keithpgdrb
    2,221
    Bolingbrook, IL
    Yeah, I've used the overhang adjustment and lateral balance adjustment as well. in fact, about twice a year, I just get frustrated and recheck everything. That is one of the reasons I'm asking for more advice. I'm no expert, thats for sure, but I just require better results then what I'm getting. As far as azimuth and vta, I'm just hoping I have eyeballed it well enough. I have no way to accurately measure those.
  10. Tarl Of Gor
    Tarl Of Gor AK Subscriber Subscriber
    5,246
    Shelbyville, IN
    Do all of your records sound the same way or just this one? It could be the record.
  11. keithpgdrb
    2,221
    Bolingbrook, IL
    my cart did come with a plastic overhang guage, but dont you have to set that to what your tonearm requires? also, you cant use the baerwald and the denon overhang guage. its one or the other right?
  12. Frank Sol
    7,790
    SoCal
    Sometimes it's the little/simple things we overlook
    1) make sure the platter is level (not the TT necessarily)
    2) inspect the stylus under magnification and make sure it is really clean
  13. keithpgdrb
    2,221
    Bolingbrook, IL
    It was most noticeable on the morrison yesterday, but I have been questioning the setup for a while.
  14. keithpgdrb
    2,221
    Bolingbrook, IL
    I'll have to pick up a decent bubble level. I was using a small construction level. but I dont think its that far off.
  15. Tarl Of Gor
    5,246
    Shelbyville, IN
    Before you go nuts over the setup try that record on another TT and see how it sounds.
  16. Balifly
    Balifly Listening Subscriber
    17,949
    Vancouver, B.C., Canada
  17. aussiedan
    aussiedan Ambition beyond ability
    611
    Victoria, Australia
    The 49mm setting really helped my PL-A45D/Ortofon. I had trouble with protractors and getting it right. This seemed to fix most issues, and with the inner groove distortion I was getting.
    I also made sure the cart was square to the centreline of the headshell. Good stereo now.
    Could it be an antiskate/ arm balance issue?
  18. hakaplan
    hakaplan Needs professional help
    10,704
    Philadelphia, PA
    As aussiedan stated, the shortcut measurement is 49mm. It will not coincide with Baerwald or ETM so don't bother comparing. They use different null points. You use either the shortcut or a protractor, but not both.
    It comes down to personal preference and the length of your headshell/slots. Baerwald and ETM push the cartridge 2-3mm forward of Pioneer's method, so if you have an original or vintage grid headshell you might run out of room. If you want to use these protractors you might be better off using a longer headshell like a Technics or any DJ clone, like a Stanton. Stevenson is very close to Pioneer, so if you're going to use that, you might as well just use the 49mm shortcut and be done with it.
  19. tubed
    tubed Lunatic Member
    13,173
    Aztlan
    I downloaded the two-point protractor that Enjoy the Music offers, secured the platter, centered the protractor and immediately found the cartridge was not centered properly within its' headshell. It didnt take more than two trys to adjust the overhang correctly on both points.
    Night and day musical difference on my Pioneer PL-51a:D
  20. keithpgdrb
    2,221
    Bolingbrook, IL
    so it seem you guys are suggesting setting the overhang at 49mm, centering the cart in the headshell, and not bothering with other adjustments? Done!! I'll try that for a week or so and see how it goes.
