boreas
"If it sounds good, it IS good." E.K.E.
I just picked one of these up and, while it's for the most part in decent shape, there are a couple of things that I'd appreciate some help with.
First, and probably simplest (at least to answer), the tonearm stub is lose, probably from shrinkage in the resonance damper that separates the stub from the gimbals. I theorize that the stub is held in place by a screw accessible only by removing the tonearm from the horizontal pivot post. Is this correct?
Second the strobe light blinks noticeably, about 4 times a second at 33-1/3 and much faster at 45, way more than the ~150% faster you'd expect if it were consistent with the increase in platter speed. Speed accuracy is acceptable if not perfect, about 33.5 +/- .03 and 45.15 +/- .05. Any guesses as to why this is and what the fix would be?
Thanks.
John
Thanks.
John
