hakaplan
Needs professional help
First you need to get hold of a Pioneer PL-600. Without that, this won't work. There were two turntables with this model number. This pertains to the first version, silver with s-tonearm. For beginners or newcomers to soldering, this isn't the best project to attack cold, so I suggest practicing soldering first. When I get to that part I'll describe the soldering technique that works best for this particular situation. Practice that technique first on a junk board before tackling the soldering here.
If you see a red "X" over anything appearing in the photos that shouldn't be there, it means it should have been removed.
See Photo 1. Remove the dust cover, mat, platter, headshell, and counterweight. Remove the black sub-platter plate by removing the 4 screws circled in red.
See Photo 2. This is a view of the underside to show the feet. Each foot is held in with a screw. Keep the turntable right side up, but slide it over the edge of the work surface just far enough to unscrew each of the screws in turn. The feet will stay attached.
See Photo 3. Remove the three white, plastic connectors as circled. Also remove the two screws, one holding a wire tie, the other attaching a ground lug to the bottom of the case. And remove the exposed screw holding down the tonearm assembly.
Move the tonearm into the platter area. Lift up the base chassis, maneuvering it over the rear of the tonearm and fold it over. See Photo 4. This is actually an "after" shot but you get the idea.
See Photo 5. Just noting here the inside springs of the feet. They were damped with a rubber covering which has probably begun to disintegrate like this one. It's up to you what you want to do about it. Maybe you can figure out some replacement like maybe pipe insulation or just wrap tape around them to secure them, or whatever. I just left them as is.
Continued in next post...
..........1......................2.....................3.....................4..................5
