Here are some pictures of a Pioneer RG-2 Dynamic Processor i recently worked on. As you can see from the picture below, there are lots of orange Elna electrolytics (low leakage) in there, and a couple of bi-polar ones as well.
Here's the board all re-capped, you can see I used low leakage Nichicon KLs to replace the orange Elnas. All the rest were KWs, with the exception of the two green ES caps at the very back that replaced the bi-polar ones.
I replaced the troublesome tape monitor switch with an ALPs one that was in an old tape deck. What happens with the original Pioneer ones is the latching mechanism breaks inside, and they won't stay in.
However, I did not have any spares to replace the "processor" switch, so I had to order one from Mouser. This replacement would not fit in the original metal cradle, the slots where it locates were wider apart, as you can see from the yellow lines I drew on the picture below.
I ended up cutting away that locating bracket all together, as you can see in the picture below.
More pics...
Lee.
More pics...
Lee.
