secrets
Member
Dad is trying to repair a Pioneer sa 708 that has a hum through the speakers even with the volume on zero .The hum is still present when the volume is raised as well .He changed the main power caps and no luck still humming . Removed the input rca jacks and still a hum coming out from the speakers and it is not low or really loud it is there even if you play music with the volume up .We cannot seem to find this problem . I would like to know if it is possible the transformer is causing some ground or feedback or could this be a open fuse resistor
or leaking cap . Any info would help fellas . Someone else had the same problem but they did not explain what they did to find and repair this fault .
