Meesterstech
I am working on a Pioneer SA-708 and would like to know if I can replace the 2SC2238/2SA968 transistors with ON Semi's MJE15032G/MJE15033G? The manual also states that these 4 transistors should be hfe matched. (unless that was someone else s notes)<br />
<br />
I found that the left channel has had most of its transistors replaced with RCA SK series, as well as the 4 output transistors on the heatsink.<br />
<br />
The Left Channel had 0mV bias reading.<br />
The Right Channel had 150+ mV bias reading.<br />
<br />
Also the 2SA949 which sets the bias for the outputs was changed on the Left Channel (the channel with a zero bias reading)<br />
<br />
Here is a list of transistors I have in stock, hoping most of these will work:<br />
MJE15032G/MJE15033G<br />
KSC1845FTA<br />
KSA992FBU<br />
KSA1013YBU<br />
KSC2383YTA<br />
KSA1220AYS<br />
KSC2690AYS<br />
<br />
Here are all the transistors I want to change:<br />
2SA726S<br />
2SC2229<br />
2SA949<br />
2SA968<br />
2SC2238<br />
<br />
I know I'm getting off topic here. Biggest concern is whether I can replace 2SC2238/2SA968 transistors with ON Semi's MJE15032G/MJE15033G.<br/>
<br />
<br />
<br />
<br />
KSC1845FTA<br />
KSA992FBU<br />
KSA1013YBU<br />
KSC2383YTA<br />
KSA1220AYS<br />
KSC2690AYS<br />
<br />
2SA726S<br />
2SC2229<br />
2SA949<br />
2SA968<br />
2SC2238<br />
<br />
