Here's my capacitor list for replacing the electrolytic capacitors in my SA-7500 II amplifier. The only capacitors that don't have an entry are the two large filter capacitors. I have posted a separate thread regarding those items since there is no exact replacement available and their replacement will require some retrofitting.
Since I didn't see a capacitor list for the SA-7500 II, I'm hopeful that this information might get archived with AudioKarma and that it may help another rebuilder in the future.
I should also add, that in addition to pulling the specifications from the service manual and schematic, I did go through the unit and confirm that at least in my unit, these are the actual capacitance and voltages for the units as installed. As per a post I read from markthefixer, I have formatted the list as a comma separated values list so that you can easily read the information into a spreadsheet. As always, if you see anything out of kilter, let me know. I'm open to suggestions and somewhat trainable (depending on who you ask!)
Nichicon PW series for the Pioneeer CEA capacitors,,,,,
Nichicon KL series for the Pioneeer CEANL capacitors,,,,,
Control Amplifier Assembly,,,,,
Capacitance,Voltage,OEM_type,OEM_value,Service_manual_label,Mouser_Pt_No
47uF,6V,CEANL,470P,C5,647-UKL1A470MDDANA
47uF,6V,CEANL,470P,C6,647-UKL1A470MDDANA
3.3uF,50V,CEANL,3R3P,C9,647-UKL1H3R3MDDANA
3.3uF,50V,CEANL,3R3P,C10,647-UKL1H3R3MDDANA
47uF,35V,CEA,470P,C19,647-UPW1V470MED
47uF,35V,CEA,470P,C20,647-UPW1V470MED
AF Amplifier Assembly,Voltage,OEM_type,OEM_value,Service_manual_label,Mouser_Pt_No
1uF,50V,CEANL,010P,C1,647-UKL1H010MDDANA
1uF,50V,CEANL,010P,C2,647-UKL1H010MDDANA
220uF,25V,CEA,221P,C9,647-UPW1E221MPD
220uF,25V,CEA,221P,C10,647-UPW1E221MPD
2.2uF,50V,CEANL,2R2P,C23,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C24,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C31,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C32,647-UKL1H2R2MDDANA
47uF,6V,CEA,470P,C35,647-UPW1A470MDD
47uF,6V,CEA,470P,C36,647-UPW1A470MDD
330uF,6V,CEA,331P,C45,647-UPW0J331MED
330uF,6V,CEA,331P,C46,647-UPW0J331MED
100uF,16V,CEA,101P,C47,647-UPW1C101MED
2.2uF,10V,ACH-317,,C48,647-UKL1H2R2MDDANA
10000uF,50V,ACH-062,,C49,667-ECE-T1KP103EA
10000uF,50V,ACH-062,,C50,667-ECE-T1KP103EA
330uF,63V,CEA,331P,C54,647-UPW1J331MHD
330uF,63V,CEA,331P,C55,647-UPW1J331MHD
220uF,63V,CEA,221P,C56,647-UPW1J221MPD
47uF,25V,CEA,470P,C58,647-UPW1E470MDD
100uF,63V,CEA,101P,C59,647-UPW1J101MPD
220uF,25V,CEA,221P,C60,647-UPW1E221MPD
220uF,25V,CEA,221P,C61,647-UPW1E221MPD
220uF,25V,CEA,221P,C62,647-UPW1E221MPD
BOM List,,,,,
Mouser_Pt_No,Quantity,,,,
647-UKL1A470MDDANA,2,,,,
647-UKL1H010MDDANA,2,,,,
647-UKL1H2R2MDDANA,5,,,,
647-UKL1H3R3MDDANA,2,,,,
647-UPW0J331MED,2,,,,
647-UPW1A470MDD,2,,,,
647-UPW1C101MED,1,,,,
647-UPW1E221MPD,5,,,,
647-UPW1E470MDD,1
647-UPW1J101MPD,1
647-UPW1J221MPD,1
647-UPW1J331MHD,2
647-UPW1V470MED,2
667-ECE-T1KP103EA,2
BOM List,,,,,
647-UPW1E470MDD,1
647-UPW1J101MPD,1
647-UPW1J221MPD,1
647-UPW1J331MHD,2
647-UPW1V470MED,2
667-ECE-T1KP103EA,2
