Pin 1 0 Voltspost all protect pin voltages .
typo pin 7 pos voltagePin 1 0 Volts
2 -16.56
3 -25.44
4 -13.02
5 -43.94
6 -62.10
7 -61.10
8 43.34
9 34.27
10 25.13
11 16.25
1 24.883 -25.44 is the problem ..this comes from right channel main amp .
its supposed to be 0v
now post voltages for right side main amp board pins .
just been going over the voltages and these cant be right .... protect board ...
5 -43.94
6 -62.10
7 -61.10
8 43.34
max voltages are +- 45v .. i can believe they are mv though .
Protect Board Voltages
Pin 1 .001
2 -13.02
3 .001
4 0
5 .012
6 .014
7 .009
8 .015
9 .011
10 34.30
11 34.30
12 .001
Pin 12 is 7.80 AC on protect board12 is AC see what its saying .. expect 7.5v AC
just checking others now
p.s pin 9 being that low says relay is clicked in or bad connection on the board . i would expect a much higher voltage there . it is supposed to be 8v as it happens .
you proved relay is good so i guess its a meter reading error .
Q6 B .9mv C .6mv E .8 mv Q7 B ,9 mv C.9mv E .9mvvoltages for bc and e q6 and q7 should get us right on it now .
just in case get voltages each side of r23
R23 3.5 volt and 34.7 VoltQ6 B .9mv C .6mv E .8 mv Q7 B ,9 mv C.9mv E .9mv
Yes, all these voltages are with pin 9 grounded.just a thought i dont suppose you are still jumpering pin 9 to ground ?
All voltages with Pin 9 not groundedYes, all these voltages are with pin 9 grounded.
