Pioneer SA 9800 moving coil performance?
Discussion in 'Pioneer Audio' started by Bound2Glory, Apr 19, 2017.
  1. Bound2Glory
    Bound2Glory New Member
    6
    Hey all!
    I'm considering a modern moving coil cartridge for my Hitachi HT-500 (something like the dynavector 10x5).
    I know that moving-coil cartridges have come a long way since the early eighties, so I'm a bit concerned about the compatibility/performance of a modern Mc cartridge with my 9800.
    Thought I'd reach out to the community and get some thoughts...
    Thanks in advance.
    Joe
    *For those who are unfamiliar with my Hitachi turntable, it has a low mass straight arm.
  2. Balifly
    Balifly Listening Subscriber
    18,847
    Vancouver, B.C., Canada
    Welcome to the Pioneer forum.
    The "dynavector 10x5" is a homc - high output moving coil cartridge that will work well with your Pioneer SA-9800 without any additional help.
    You will need a SUT- Step Up Transformer with lomc- low output moving coil cartridges though. :music:
  3. Bound2Glory
    6
    Cool... So I would be able to fit the dynavector on my turntable and plug the turntable directly into the moving coil input of the 9800, simple as that? No step up or pre-amp needed?
  4. Balifly
    18,847
    No need to use the moving coil input, just use the mm phono input. :music:
  5. Bound2Glory
    6
    Really!? Because of the high output I assume
  6. Balifly
    18,847
    That is correct. :thumbsup:
  7. Bound2Glory
    6
    Any thoughts on whether or not the performance of the dynavector would be hindered at all?
  8. Balifly
    18,847
    No reason why it should be hinder by the phono setup.
    Some things you should check to make sure that it will be able to perform at its best.
    Check headshell wires and clips for proper contact (erosion).
    Check for proper cartridge alignment in the headshell.
    Check and make sure the azimuth of the needle and cantilever are correct.
    Enjoy! :music:
