Pioneer sa-9800 output issue
Discussion in 'Pioneer Audio' started by jeffV, Jul 11, 2018.
  1. jeffV
    jeffV Active Member
    140
    Ok guys, I need help.
    I picked up a 9800 that has an output issue, very little output. I took it to a local tech, and he has had it for two months now, and he says the cause of the issue "escapes him" ...ugh...
    He says it is showing excessive voltage on the output section, he says there should be no voltage, but he is showing something like 70 volts on the output side?
    I am going to go pick the unit up as I now have no confidence in his diagnostic abilities.
    does anyone here want to jump in this one? I really want this thing fixed, or i may just sell it as a parts unit?
  2. petehall347
    28,344
    uk.. the middle bit
    70 volts shouldn't be possible .. max it can be is 55v .
  3. slimecity
    slimecity Super Member
    3,244
    New Zealand
    Pick it up and we will try to run through some things. The fact he is measuring voltage on the output suggests that at least, your speaker relay is engaging!
  4. petehall347
    28,344
    uk.. the middle bit
    most likely be 70mv .. not 70 volts ..
  5. jeffV
    jeffV Active Member
    140
    ok, he said it is 52 volts. The amp was working when I took it to him, but it had an audible hum, and the sound output was extremely low. I will be picking it up tomorrow.
    please stand by...
    thanks
  6. jeffV
    jeffV Active Member
    140
    ok guys on his notes, it says the Darlington output base should be .7v. it is measuring 50 volts. says he disconnected output, no leakage, still high.
  7. jeffV
    jeffV Active Member
    140
    Anyone?
    Leaning towards selling for parts...
  8. redk9258
    redk9258 AK Subscriber Subscriber
    1,642
    Illinois, close to St. Louis.
    That's a shame. Hopefully someone will be along to help you out.
  9. petehall347
    28,344
    uk.. the middle bit
    sorry but your picture wont enlarge for some reason .
  10. reddish75
    reddish75 Active Member
    217
    Take it to a reputable tech, ask for recommendations on here for ones in your area
  11. Watthour
  12. tekdoog
    tekdoog New Member
    2
    still leaning towards parts. could use the volume knob if mint
