The amp seems to be working fine, but then if I increase volume, the output will cut off and on (with a clicking noise that would seem to indicate an internal protective relay has been triggered) until I reduce volume enough to prevent that from happening. I'm not bringing the volume up to any very high levels, certainly not anything that should cause a problem. Any thoughts on what the problem is and what steps I should take to cure or repair would be appreciated.
