Pioneer spec 1 and spec 2 connection
Discussion in 'Pioneer Audio' started by rocknroll1, May 10, 2017.
  1. rocknroll1
    rocknroll1 AK Subscriber Subscriber
    749
    Huntsville, Al
    I have never had separates and need help hooking up. Please let me know if this is correct; Speakers into amp, TT and CD player into pre and pre into amp. 2 questions, 1) how to adjust volume 2) what is the ground post for under amp input?
  2. macyjrm
    macyjrm Super Member
    1,309
    Mississippi
    Volume is controlled by your preamp. Think of your amp as the engine and your preamp as the gas pedal. Not sure about your question 2. Usually ground posts are for grounding a turntable to prevent hum. The TT ground post is usually located adjacent to the phono input jacks. Hope this helps.
  3. rocknroll1
    749
    Huntsville, Al
    so do I hook speakers up to amp or pre
  4. macyjrm
    1,309
    Mississippi
    Speakers should be attached to the amplifier. The amp provides the power necessary to drive the speakers.
  5. bberkom
    1,561
    Nashville, TN
    Source (tt or CD) > Preamp > Power Amp > speakers.
    You should adjust listening volume using the preamp controls. You can use the level controls on the power amp to adjust balance and gain for the power amp stages, but once you set the power amp, you shouldn't regularly adjust the amp settings, just the preamp controls.
  6. slow_jazz
    slow_jazz AK Subscriber Subscriber
    13,917
    SE Michigan, Downriver....
    You can run very short wires from the amp to the pre-amp on the spec 1.
    Then hook your speakers up to the spec 1.
    This way you can use the headphone jack also. Otherwise you won't get any sound out of the headphone jack.
  7. DrumminDaddy
    DrumminDaddy Hit it, Baby !!
    2,333
    Lost in musing circumstances
    slow_jazz is correct. The Spec 1 is a bit unique in that the output of the amp is looped back into the pre-amp. The speakers are then connected to the pre-amp. This allows the headphone jack to function as well as giving function to the A/B speaker selection. If you are only running one pair of speakers, and/or do not use the headphone jack, you can certainly hook your speakers directly to the amplifier and it would work as well.
  8. bberkom
    1,561
    Nashville, TN
    Well, the more you know!
  9. rocknroll1
    749
    Huntsville, Al
  10. rocknroll1
    749
    Huntsville, Al
    thanks for all the help, I got it hooked up, running speakers to preamp and pre to amp. One last question, will it overheat the amp with the pre sitting on top of it? Also I am getting some popping thru the right channel, do you think it is more than likely coming from the preamp? Clean the pots?
  11. HiFiThor
    HiFiThor Active Member
    211
    Do not block the flow or air through the Spec 2 power amp. It would be OK to place the Spec 2 on top of the Spec 1 preamp provided the feet are on the Spec 2 lifting it off the sheet metal top of the preamp.
    The popping most likely is coming from a faulty capacitor in the Spec 2 somewhere on the driver board which is attached to the finned heat sinks. The board behind the meters is almost all made up of the protection and meter drive circuitry and usually doesn't affect any sound quality. You must be very careful poking around inside this amp. There are thermistors screwed to the edge of the heat sinks on top towards the back. The leads on these components are very brittle and are easy to break. I had to use a dremel tool to grind back enough of the epoxy to get enough of a bare lead to solder on a wire to keep them functional. The thermistors sense high temp conditions and send a signal to shut down the amp to protect it.
  12. rocknroll1
    749
    Huntsville, Al
    Thanks, I will pass this info to the tech working on it. I am not very capable of working on these past cleaning switches.
  13. Ed Parks
    Ed Parks New Member
    5
    Jamestown, NC
    I have the Spec 1 and Spec 2 setup. I want to listen to music thru the headphones without turning on the power amp. Is there any possible configuration that will allow the headphone jack to receive audio without turning on the power amp?
  14. miklemke
    miklemke AK Subscriber Subscriber
    865
    For the headphones to work, you must have the Spec 2 outputs run back into the Spec 1 and both the Spec 1 & 2 turned on. The Spec 1 controls the volume. If you just want the headphones on and the speakers off, turn the Spec 1 Speaker switch to "Off".
