Randy007
Hi..I have a Pioneer Spec-1 Power Amp I'm trying to get back in service. My problem is all the B+ and B- voltages are way low measuring 7 volts and 0 volts when I should be reading +48 and -48...also I have no out put voltage from the fuse circuit Bd. to the Power Supply board...also all voltages from the fuse circuit board to all other boards is reading low voltage to 0 voltage, also low voltages from Power supply board to other boards low to 0...I was reading low voltage on the caps on the fuse board, 2 caps are rated to 80v AND 1 is rated to 50V..should I replace these and the 6 diodes on this board...I have voltage coming into the unit, the speaker relays kick on, but nothing else....help
