PIONEER SX-1250 NEW CASE BUILD
Discussion in 'Pioneer Audio' started by sawdust, Nov 11, 2017.
  1. sawdust
    sawdust Solid walnut covers all my gear Subscriber
    324
    Michigan
    This time I want to share how I make a Case out of solid walnut it time to dress up my SX-1250
    Off to the scrap pile to pick out the stock this board is 90 inches long and 5 inches wide. I will half to cut it in half and glue it together to get the width I need I will cut it now ,next I will pick out and mark the best grain match now off to the jointer to straighten the outside edges I will do all 4 edges now that way after gluing them together I will have a straight edge when I rip to width on the table saw
    after joining the edges I got a good grain match I'm happy with it so I will glue them together I use Titebond III wood glue I let the glue soak for a minute or two before clamping them together
    IMG_5477.JPG IMG_5481.JPG This is the under side that won't show when finished remember I got this board out of my scrap pile IMG_5483.JPG Be back after glue dries
  2. sawdust
    324
    Michigan
    Now that the glue dried over night it's off to the table saw to parallel it to width hopefully their will be enough left over to make some face blocks . after ripping one side I set my fence using this side pattern I made I add 1/8" extra that way I cam parallel it to exact width after the planer
    Now that it parallel off to the jointer to flatten one side
    my old case measures 0.485 thick this is my target thickness my planer has a digital readout accurate within + or - 0.001" so off to the planer
    now back to the jointer to straighten one edge I will remove about 0.020
    I set my fence on my table saw using the pattern I made put the jointed edge to the fence and rip it to width.
    be back after lunck
    restorer-john likes this.
  3. sawdust
    324
    Michigan
    Time to cut the miters Tilt the blade exactly 45 degrees, I modified my miter sled with simple through bolt stops so their is no measuring quick easy, I use a forest woodworker 1 thin kerf blade 1/6" thick to minimize material loss at the miter joint I have dedicated this blade solely for this use , I mark my top side with frog tape it doesn't pull out the wood fibers like the blue painters tape does then center the old case on the new piece and mark it this gives me a reference where to start
    After cutting the top right miter I turn the right side to the fence and cut the right side miter save the fall out will use them later on for the corner braces
    Now I bolt the top stop in and cut the left miter for the top then turn the left side to the fence and cut the side miter again save the fallout piece,
    how to check the miter joints, I but the sides to the fence and see if their is any gaps if you have any gaps your miter sled needs adjusting
    back later
  4. sawdust
    324
    Michigan
    Time to change the blade back and cut the sides , I set my stop on my cross sled using the pattern I made then cut both sides
    Time to finish the top I made a pattern for this I use two sided tape to hold the top in place off to the band saw
    I cut the back of the top out at the band saw then to the router table to finish it with a trim bit
    Now I mark the top to router out the under side , I use the old case and a square to transfer my lines off to the router table to finish the top set the bit height 0.220" and fence depth 1.050" from the far side of the bit I put reference lines on the fence to indicate the width now only router the under side between the lines . then set the fence depth to 0.670" to the far side of the bit , I do my first pass backwards to illuminate the possibility or any tear
    IMG_5577.JPG IMG_5575.JPG be back later
    Imanoldee likes this.
  5. sawdust
    324
    Michigan
    now mark the top to router the back out I use the old case for this, I use a 1/4" bit for this set bit height to 0.240 and fence depth to 0.775 from far side of the bit then cut the depth, reset the fence to 0.255" from far side of the fence then cut across both ends of the back
    Now for the mounting holes, I use a router with a 3/4" collet a 1/4" bit to bore the holes and a 0.550" bit to counter sink them. I took the sharp edge of the counter sink bit this illuminates the possibility of tear out .
    I just line the template to the sides clamp it bore the holes 1/4" and then counter sink them 0.190" deep
    IMG_5556.JPG IMG_5557.JPG back later
    restorer-john and redk9258 like this.
  6. sawdust
    324
    Michigan
    Cut the corner braces out of the pieces saved from the miter cuts need 4 of them 1 15/16" wide
    Time to glue it up, I but it up to the fence on my table saw to keep it straight making sure the miter joints are tight then use frog tape to hold them it place the tape also it will illuminate any glue squeeze out , I let the glue soak for one to two minutes before gently clamping it, then I glue the corner braces in and check both sides for square let the glue set I will finish it tomorrow
    Aaron99 and restorer-john like this.
  7. restorer-john
    restorer-john Addicted Member
    5,596
    Australia
    Oh my goodness. This is a masterclass.
    Thanks so much for sharing. :)
  8. sawdust
    324
    Michigan
    I'm back
    Now that the glue has set we can remove the frog tape and see how it looks
    Time to cut the tongue on the top, I set my fence using the pattern I made, the old case measures 0.075" bump the fence toward the blade 0.075" the old case measures 0.130" down from the top I raise the blade height to 0.130" I also made a piece to fill in the back of the case where the cut out is that goes to the fence I secure it with double side tape this keeps the top straight on the fence
    then I cut the tongue should end up with 0.135" x 0.130 and 0.075 deep
    Now I score the tongue using the old case I use my knife then raise the blade to the score line and cut both sides
    Be back later
  9. sawdust
    324
    Michigan
    Now I square up the back corners with a sharp chisel
    this step is optional some Pioneer SX-1250 cases did not have the vent screen block cut 2 pieces 1.565''L X 0.240"H X 0.200"W glue them flush with the bottom
    time to make the face blocks remember the piece I saved when I cut width , I use the plainer for this step you can also make them on the table saw I plane one side then rotate 180 degrees set my plainer to 0.995" finish plane the depth
    rotate the piece 90 degrees plane it them rotate 180 and set the planer 0.730" and finish plane the width.
    Back to the table saw set the stop on the miter gauge to the original face block and cut them to length that wraps all the wood work time to give it a finish sand and stain.
    be back later
  10. sawdust
    324
    Michigan
    now it's time to give it a good sanding and put some stain on it , Picture before sand and stain.
    I will be back tomorrow
  11. ZeroJunk
    ZeroJunk Super Member
    1,124
    Browns Summit N.C.
    My father was a carpenter and cabinet builder, but nothing of that precision. I can appreciate how cool that really is.
  12. peerson
    peerson Well-Known Member
    587
    Kansas City area
    I would LOVE to do this on my SX1250! But, I do not have the skill or the equipment to do it right.
  13. redk9258
    redk9258 Super Member
    1,416
    Illinois, close to St. Louis.
    Norm Abram would be proud!
  14. zebulon1
    zebulon1 Getting behind on work. I need help? Subscriber
    4,636
    Las Vegas Nevada
    I'm fascinated with the process and you make it look like I could make one.
  15. sawdust
    324
    Michigan
    All done with the finish after a final sand and a coat of stain it turned out looking good for the board I used.
    This project was fun to share I have made a few dozen maybe more that why I made patterns to keep it simple if your only going to make one just copy your old case.
    I have had several original pioneer SX-1250 cases pass through my shop they all measure different the old case I use to copy fit my SX-1250 the best .
    DrumminDaddy, redk9258 and LesE like this.
  16. macyjrm
    macyjrm AK Subscriber Subscriber
    1,141
    Mississippi
    Sawdust, I'm the proud owner of one of your cases. So much better than what the factory built! Well done, sir.
  17. tsd71
    tsd71 RIP Tom Petty Subscriber
    2,569
    New Jersey
    As always very nice work Amos, thanks for sharing your knowledge!
  18. peerson
    587
    Kansas City area
    What would it cost to have you make me one?
  19. kramden
    kramden Active Member
    159
    Workmanship is impeccable but what is more amazing is Sawdust's tissue re-generation abilities! ;)
  20. Awesomeaudio
    Awesomeaudio AK Subscriber Subscriber
    1,152
    Sydney, Australia
    Excellent :bowdown:
