Pioneer SX-1250 - Restored, but essentially useless
Discussion in 'Solid State' started by onwardjames, Jan 13, 2019.
Tags:
  1. onwardjames
    16,692
    Kentucky
    Hello everyone!
    I have a restored SX-1250, got a full, ground up rebuild/recap back in 2014. When I got it back, I was very impressed with the work, but there was some static in that Alps sealed pot. I asked my tech, and he said "it was sealed, so I couldn't do anything with it."
    I am not complaining about the quality of work otherwise....but it is essentially useless. Even leaving it on for days and working the volume back and forth, it's horribly noisy and drops the left channel a bit.
    I am desperate. Has anyone had luck cleaning that infernal master pot?
    Thanks, everyone.
  2. embrown057
    embrown057 Active Member
    234
    Apollo Beach,FL
    Your going to have to remove the pot from the board and dissemble it. I've see a few of these that the carbon track has wore out, no repairing that. You can give it a try or troll the Bay for a replacement and hope it's in good shape. ALPS still has 50K Blue pots that may work with some modifications.
    slimecity likes this.
  3. onwardjames
    16,692
    Kentucky
    Thank you greatly. However, that's beyond the scope of my abilities.
    Damn these needy receivers. This one has been a continual headache for me since getting it back in 2008.
    Ds2000 likes this.
  4. UncleBingo
    1,828
    Welp... you didn't hear this from me, but I've seen the occasional sealed pot with small holes drilled in it for to spray in some deoxit. They were covered in black electrical tape to keep crud from working it's way in there. Wasn't a 1250, but a lesser piece like a Rotel preamp or something like that. It's time consuming, but I usually pull the pot and loosen the screws enough to get some deoxit in there. If the pot isn't mounted to a circuit board, it isn't very labor intensive at all.
  5. willyrover
    willyrover Super Member
    3,184
    Hamilton
    You could create a small hole in each section of the pot with a thumb drill or a pin file. Go slowly and keep vacuum on it so the plastic bits don't fall into the pot.
    Deoxit through the hole.
    Cover the hole with a piece of tape or dab of silicone.
    slimecity, elnaldo and UncleBingo like this.
  6. leesonic
    leesonic Hold on, here comes the bass. Subscriber
    4,697
    Southern NJ
    How easy is it for you to remove the pot and send it to one of us? Is it on a seperate board with wire wraps on it?
    Lee.
    Goldie99, onwardjames and UncleBingo like this.
  7. Tom B
    1,585
    Bay Ridge, Brooklyn New York
    I have also found that if you remove the front panel, and pull the control amp board (nuts on the controls and screws for the switches, you can unscrew the 2 screws that hold the alps together. push these skinny long screws out of the control, being careful not to lose the small nuts in the back. I have found that I can "Split the sections" just enough to get some faderlube in the to clean it, without having to unsolder it. I am nervous about unsoldering those controls as the contact are very brittle and break easily. Then reassemble and put it back together and test
    But before doing all of that, test with a voltmeter and make sure you don't have any DC on any of the volume control contacts. If you see anything above 8mv to 10mv, suspect that one of the coupling caps is leaking DC.
    DC on the control will give the same symptom as a "dirty" control, and at times worse. If you find some DC voltage, Suspect C9, C10, C11, and C12. Also check to make sure they are installed with the correct polarity, as I have found board marking errors in pioneers. Those caps are used as a pair with the Negative leads tied together electrically. So the two 22uf caps (C9 and C11), as well as the two 22uf caps (C10 and C12), actually become the same as a 11uf bipolar cap in that way. Seeing that you had a full restore done on it, there could have been an issue with the install of those caps. C9 and C11 are for the left channel and C10 and C12 are for the right channel
    wlhd1610, Ds2000, LesE and 1 other person like this.
  8. gort69
    gort69 AK Subscriber Subscriber
    1,180
    Vancouver, WA
    If you do that be very careful. I bought a Kenwood Model 500 someone had done that to and they destroyed the pot. I think they used their Milwaukee hammer drill on it.
  9. UncleBingo
    1,828
    You have to drill in the center of the module (away from the individual section demarcation seam line)
  10. willyrover
    3,184
    Hamilton
    Yes, hand tools only. You don't want the bit punching through into the pot.
    UncleBingo likes this.
  11. UncleBingo
    1,828
    A "Pin-vise" is perfect for this sort of thing.
  12. waggs098
    waggs098 Super Member
    1,272
    Kearney, NE
    Same style of pot that's in an MCS 3275. As someone posted earlier I was also able to remove the screws and separate the sections enough to get deoxit in and clean it. Worked for me anyways.
  13. gort69
    1,180
    Vancouver, WA
    I've never even considered drilling one of these. You can get cleaner into them, right where the solder tabs come through. I use the aerosol, and it makes a big mess, but it works. I only had taken this one apart to repair it.
    Ds2000 likes this.
  14. Ds2000
    Ds2000 Oh THOSE speakers. Subscriber
    5,579
    New York City
    I have done this pot separation cleaning with good success. I’d recommend following these instructions. Tom knows his stuff.
  15. onwardjames
    16,692
    Kentucky
    THANK YOU EVERYONE for you replies. I think I might give a shot at getting a little deoxit in there.
    I think the pot has just become very corroded, so I'll tear it apart and see what I can do.
    Again, thanks so much, everyone! This was a gift from the wife, so.....
    ETLS and UncleBingo like this.
  16. KingBubba
    10,198
    Brooksville, Fl.
    Drilling may work but is a risky deal. The only Alps I worked on was on My Pioneer SA-900II. I did as Tom B described roughly. I loosened the bolts enough to separate the slices, but not pull the bolts out. I separated each slice and used Deoxoit D-100 mixed 50/50 with low aqueous isopropyl alcohol in a needle bottle. In each slice, I would generously squirt the mix and then cycle the knob rapidly and for a good amount of time for each slice. Keeping the blue workshop paper towels underneath, I avoided having overleak. After a good long wait and some more cycling, I used D-100 by itself for a layer. Again a waiting period. I followed the same full strength application of F-100 Fader and then Caig Shield. That was about 10 years ago and I still have had no issues. When I describe the %0/%0 mix in the past, Caig gave me a like on my post. This mixture is great for flushing badly gritty pots, etc..
    I hope you will try this method as it works well and your reputation would help spread this around AK and elsewhere. I too was very wary of pulling the pot apart; so my method is a good stop-gap method. I have never used D-5, because you run a chance of dissolving the contact's attachment inside the pot. I have never had a backfire with my method. Good luck to you.
  17. onwardjames
    16,692
    Kentucky
    While I sincerely appreciate this technical info, I'm pretty certain this has been around since before the restore.
    The guy who did it is a respected tech here on these boards, and I hate to sound like I'm complaining, but it is a bit frustrating to drive 6 hours to get to someone's house, drop it off, wait 4 months, drive 6 hours back to pick up, only to have noise in this damned pot.
  18. MCS Guy
    MCS Guy The MCS hoarder Subscriber
    600
    FL
    Just remove one of the bolts securing the pot together, insert your deoxit straw, finger over the hole on the other side, and spray while pulling the straw out. Always worked for me on my MCS 3125
    Ross6860, merlynski, quiet and 3 others like this.
  19. onwardjames
    16,692
    Kentucky
    It does it, even with muting engaged and the volume at a dangerous 12 o'clock. It's grit and corrosion in the pot, as once you've found your preferred volume level, it tends to be okay. Just don't think you're gonna alter it without some degree of headache.
    @KingBubba I plan on using that method you described. I also will not use D-5 due to what you stated. Thank you, sir.
  20. onwardjames
    16,692
    Kentucky
    Lee, you're always so generous with your time and expertise. I have every hope that one day I can hand deliver that M504 and P304 for a full rework via your skills. I haven't forgotten. Me and the wife are due a trip up the east coast, anyway.
    Thanks, man.
