Pioneer SX-1280 won't power on!!!
Discussion in 'Pioneer Audio' started by Spencer Bell, Sep 13, 2018.
  1. Spencer Bell
    Spencer Bell New Member
    15
    I recently bought a Pioneer SX-1280 from a thrift store, and I bring it home, flip the switch, and nothing happens. The switch doesn't seem to click when flipped, but rather moves smoothly as if it isn't catching anything. I really would prefer to fix this myself rather than ship it off to have it serviced. Hope you all can help!
  2. Watthour
    If you feel the switch is a problem, you can unplug the unit, jumper between the switched and unswitched receptacles on the rear, then plug the unit back in. This will effectively eliminate the switch. If the switch is indeed the problem, replacements may be difficult to find, but not impossible.
  3. avionic
    45,588
    Fort Dodge, Iowa
    The SX-1280 has a soft-start circuit. There is a thermal fuse located under a large ballast resistor. If that fuse is history. Check your output transistors. One or more of them is probably shorted. The ballast resistor could be cooked as well.
    merlynski likes this.
  4. avionic
    45,588
    Fort Dodge, Iowa
    Big ballast resistor is seen on the far left edge of the board, Below the black DEC relay. The thermal fuse is under it, You can see the lead of the fuse sticking out from under the resistor.
    Hyperion and slimecity like this.
  5. Watthour
    Fortunately, jumpering the the receptacles will not bypass the soft-start array.
  6. avionic
    45,588
    Fort Dodge, Iowa
  7. avionic
    45,588
    Fort Dodge, Iowa
  8. IMF_Pioneer
    IMF_Pioneer Active Member
    211
    Australia
    I wish our thrift stores in Australia had such gems in them !
    Hyperion likes this.
  9. avionic
    45,588
    Fort Dodge, Iowa
    Do you have the tools ? Can you follow a schematic ?
  10. Spencer Bell
    15
    Seems a little complicated, but something I would like to do myself! Probably could use a step by step guide.
  11. avionic
    45,588
    Fort Dodge, Iowa
    Step one..Measure the resistance of the thermal fuse.In circuit will due.
  12. KingBubba
    10,122
    Brooksville, Fl.
    I have a 1280 and love it. The output transistors are in an unusual mounting situation. The transistors are truly unobtanium, but there's a workaround here on AK somewhere. I think it was either echowars or markthefixer that pulled that together. avionic has probably done that too. He is a great helper. He was the first person on AK to give me assistance. You are lucky to have his assistance. Do a search and you may just find it if you need it later. Good luck on your challenge. Nice receiver.
    avionic likes this.
  13. avionic
    45,588
    Fort Dodge, Iowa
    This is true.I have already located that thread by markthefixer.;) I suspect it will be needed.
  14. KingBubba
    10,122
    Brooksville, Fl.
    I knew that you would. You are just that kind of guy.
    mgkfifty likes this.
  15. Spencer Bell
    15
    Ok so I found the problem! The power switch has been disconnected, but there is another problem. There is a white wire that runs from the switch to somewhere that I accidentally pulled out when I was trying to free the slack up on it so it would reach. I ended up pulling it out of somewhere, and I don't know where it came from. Thanks!
  16. avionic
    45,588
    Fort Dodge, Iowa
    How are your soldering techniques? The white wire will be easy to figure out. It goes back to Pin 2 on the little circuit board with 4 fuses (AWX-126 or -139 ) whichever board is installed in your unit.
  17. avionic
    45,588
    Fort Dodge, Iowa
    The switch may be fixable..
  18. avionic
    45,588
    Fort Dodge, Iowa
    You need to go buy a lotto ticket. Lucky man..
  19. Spencer Bell
    15
    My soldering techniques are very bad (probably because I have never done it before) HAHA
  20. Spencer Bell
    15
    The board on the underside of the receiver?
