If I understand correctly the 'switched outlet' powers on and off with the power switch, but the Receiver stays dark and silent? If so the switch is not the problem.Pioneer SX-450 does not power on power but switched outlet works
Thank you for the reply. If I have measured the right points then I am getting an open reading. I have attached a photo of where the brown and white wire terminate. Thanks again.
You're welcome! If you become a Subscriber you can post a 'Part Wanted' in Bartertown Parts and some other AKer may have a transformer for a reasonable price.Thank you for the help.
Good photo, that round device in the heat shrink is a capacitor. The open reading tells me the transformer primary winding has failed open. You will need to replace it to (first step) get this unit working again. Sometimes transformers have internal thermal fuses that open if they overheat. These fuses are difficult or impossible to replace. The schematic does not show one for this transformer, and low power amps are less likely to have them, from what I have seen. Good luck!
If the transformer is removed, it can be partially disassembled. There MAY be a thermal fuse under the steel covers, and if it present it is likely bonded to the winding. It can be accessed to check for continuity, and may be replaced with a similar thermal fuse if care is exercised.
Not likely that cap is the cause of no power. It is there to reduce arcing across the switch contacts, if it failed open for switch would (maybe) burn its contacts, which might cause a no power situation; if it failed closed (shorted you would not be able to turn off the power. With it unplugged from the wall, measure across the transformer primary winding with your ohmmeter. A good winding/thermal fuse will read only a few ohms, if it reads infinite ohms either the winding or the thermal fuse is open. You can also measure across the switch, one position should be zero ohms, one should be open (infinite ohms). Can you post a picture of the cap?Hello all to wake up an old thread. I have the same issue, with no power but switch working fine. The round capacitor in the heat shrink in the picture... on my receiver this looks blown. Woult this be the cause of the power issue? Any help would be much appreciated.
