Welcome to Audiokarma.
Have you checked the protection fuses on the back panel? Should be under a square cover on the back panel next to the AM antenna mount. An SX-535 was my first restoration project. When I got it sounded like it had a major head cold. Was recapped and a lot of transistors replaced and its fidelity returned. I pulled it off the shelf to use as a reference.
If a fuse is blown you can replace it but don't hook up speakers to the unit. Check the DC at the speaker terminals first. When output transistors blow they often short collector to emitter which can put a large DC voltage on the speaker terminals which can quickly fry woofer voice coils. Creates a contest for which fails first, woofer voice coil or the protection fuse. Fried a woofer one time not checking for DC on the outputs on a unit new to me with unknown history. It was putting out 35 Vdc across the speaker terminals on one channel.
For reference below is a picture of the amp board out of mine. It has been recapped and a number of transistors and several resistors replaced.
Fortunately these are very repairable, plenty of information on this site for recapping one and replacing transistors. Plenty of helpful people can chime in and help someone fix them too. A common vintage low power Pioneer receiver. Nice looking and solidly built.
