riverty
New Member
I purchased this Pioneer SX-535 from a local shop. With the exception of the broken face plate in the tuner window, the unit is in great shape inside and out. All original and in working order. So, I decided that this would be a great unit to rebuild.
Power Supply: I replaced the main filter caps with new Nichicon LKG Gold Audio Grade caps at 6800uF @ 63V. A bit higher than the original 4700uF caps but that's all I could get and no harm done. I replaced the bleeder resistors with new 5 watt resistors. All electrolytic caps on the power supply board (AWR-065) were replaced with new long-life Nichicons or Panasonics, depending on what was available from Mouser. All diodes and resistors were checked and found in good working order. I did add a small heat sink to the 2SD234, mostly because I had one around and, why not?
Control Board: I replaced all electrolytic caps with new, long-life Nichicons or Panasonics. I also replaced all the light-blue Sanyo caps with new Cornell Dubilier, DME Film caps. All pots and switches were cleaned with DeoxIT.
Tuner: All 6 light-blue Sanyo caps were replaced with new Cornell Dubilier, DME Film caps.
Phono Preamp: All electrolytic caps were replaced with long-life Nichicons or Panasonics. I also replaced all 4 original 2SC1312 transistors with better sounding Fairchild KSC1845FTA transistors. Resistors were checked and found to be fine.
Power Amp: All electrolytic caps were replaced with long-life Nichicons or Panasonics. The troublesome 2SA726 transistors were replaced with new Fairchild KSA992FBU transistors. Resistors were checked and found to be fine. I also replaced the original bias pots with new Bournes 362-line pots and set the bias at exactly 15mV for both channels as per the service manual.
Front Panel: I decided to replace all the incandescent lights with LED's. I used a bridge rectifier and dropping resistor to power the whole display. I added 10 blue LEDs to the tuner dial, an orange LED for the tuning indicator, and white LEDs behind both tuner meters. I then replaced the stereo indicator with a red LED and appropriate dropping resistor to suit.
And finally, I gave the whole thing a good cleaning, inside and out. Everything works prefectly and sounds amazing!
There were several posts in a few different forums that I used to gather the best information about the unit, replacement parts, and things to check, and I can't thank them enough for their wisdom on this project. It definitely pays to take some time and research things before you order parts and start work. Hopefully, the information in this post, plus the pictures will help someone else wanting to do the same.
Cheers all...
Cheers all...
