trump
New Member
Hello everybody, I am pretty new posting because I only recently bought a vintage receiver on ebay, a Pioneer SX-636. It was about $160, not sure if I overpaid or not but you live and learn right? So far, I've only cleaned it up using contact cleaner and dish soap/water for the faceplate and knobs. Everything seems to be working for the most part except for the FM indicator lamp which I've already ordered a whole new set of lamps from dgwojo.com. The first thing I want to do is replace the fm indicator lamp & the main dial lamps.
However, a bigger concern of mine is the FM reception/signal strength. When using the FM tuner, only 2-3 channels come in clearly and they come in very clearly with no static at all, and the stereo light turns on as expected. The problem is all the other channels is just static. Why would 2-3 channels come in perfectly clear but the rest just pure static? I've read the blue sanyo caps can cause issues but are those related to getting a FM channel to come in or the sound itself? Because when a channel does come in, it's crystal clear. I tried using contact cleaner on the brass contacts in the FM tuner itself but still only 2-3 channels come in. Could there be some interference going on or just a weak antenna?
Sorry if I am asking obvious or stupid questions but thank you ahead of time for the help!
Edit: I plan on fully recapping and doing whatever else is needed but I am not sure if the FM issue is related to that or not..thanks guys!
