Got this Pioneer SX-650 stuck in protection. All power supply voltages are as per manual. Relay itself seems ok. Output modules are not shorted. DC offset is around 30mV in each channel.
Started going through protection circuit. Q11 and Q12 have their 0V on each base (no DC offset in each channel). +21V on each collector is present, so this pair must be ok?
Now get to Q13 and Q14, and voltages are all over the place. Simple junction test in-circuit shows transistors are at least not shorted.
Q13 Vdc readings:
* base: 1.5V
* collector: 0.7V instead of -1.5V
* emitter: 2.1V instead of 17V
Q14 Vdc readings:
* Base: 0.7V instead of -1.5V
* Collector: 0V instead of 13V (so Q15 is turned off)
* Emitter: ground
D7, D8, D9 - junctions seem ok according to my multimeter. I replaced 4 electrolytic caps "just in case" in the circuit - no change. Interesting that C36 was 100uF/16V instead of 220/16 (my parts 650 has 220/16, which matches the manual).
Should I disconnect D7 and see if the circuit works, or replace Q13 and Q14?
I think substitutes are:
Q13 - 2SA823 PNP - KSA992FBU
Q14 - 2SC1647 NPN - KSC1845
Thank you!
Q13 Vdc readings:
* base: 1.5V
Q14 Vdc readings:
* Emitter: ground
Thank you!
