rocknroller
Problem: All audio sources are muted in the power amp section - no output from speakers and no blown fuses.
Using Aux as the input source path, I get audio past the preamp at the test point jumpers 72/44 and 43/72. Audio through caps C511/C512, but not through Q503/504 (Listed as 2SK117-GR or Y, 2SK34-C or D - I guess these are audio gates?). See schematic below
Following back through D503/504 (which are good) to the left hand side of the circuit, this seems like the controller of those gates but Q502 collector has a bad voltage of -8v. Why?? This may not be the ultimate source of the amp issue, but seems to be why the audio isn't progressing any further in the circuit.
