A great deal. I have too many projects to add this to them.
https://portland.craigslist.org/mlt/ele/d/pioneer-receiver-sx-680/6458784166.html
I'm also shocked. If no one picks it up tomorrow, I might just do it myself. I drive right by the place on my way to work.
Mike
Should be picking it up this weekend....
Fingers crossed it's nothing I can't fix.
Did you end up getting it?Should be picking it up this weekend....
Yup. Haven't opened her up yet though.
I repaired two SX-680s for a friend, both lit up and had no sound. I expected the STK modules were dead.
Both were the same part, a resistor (can't remember the value) that opened in the power supply dropping power to the preamp.
Either my friend is very very lucky, or this is a common failure. I replaced PS caps while I was in there, they tested a little on the low side but not bad, no idea why the resistors opened (no signs of heat either).
I hope that you're as lucky. If yours has the same symptom PM me and I'll look up what resistor it was (but should be easy to find, closest to the back of the unit, two in a row, one closer to the tuner side of the receiver IIRC).
