gkhashem
I have just cleaned the unit and replaced the dial bulbs with some white LEDs. I left the meter bulbs for now since I was not in the mood to play with them but they do work as do all the other bulbs.
I dusted the unit out since it was slightly dirty now I had a question.
I looked at the boards on top. It appears the tuner board is on the right side. It is the only one with the sky blue caps. Are these the ones that are the Sanyo capacitors that will fail? No other board on top had any sky blue caps.
Is my observation correct. It looks like an untouched unit. But I am by no means an expert. So would I be correct and should I get the sky blue capacitors replaced?
Thanks for any input.
