Awesomeaudio
Super Member
Pioneer SX-750. 2017 UPDATED' BOM LIST
Semi Conductors, Diodes and Misc.
Power Amplifier Assembly
AWH-046 Q3 2SC1438-V vas 512-KSC2383YTA
AWH-046 Q4 2SC1438-V vas 512-KSC2383YTA
AWH-046 Q5 2SD357-C driver 512-KSC2690AYS
AWH-046 Q6 2SD357-C driver 512-KSC2690AYS
AWH-046 Q7 2SB527-C driver 512-KSA1220AYS
AWH-046 Q8 2SB527-C driver 512-KSA1220AYS
AWH-046 D1 1S2473 512-1n4148
AWH-046 D2 1S2473 512-1n4148
AWH-046 VR1 100ohm 652-3386H-1-101LF (Maybe 652-3352V-1-101LF is a better fit?)
AWH-046 VR2 100ohm 652-3386H-1-101LF (Maybe 652-3352V-1-101LF is a better fit?)
Power Supply & Protection Assembly
AWR-099 Q1 2SC869-C o/c 512-KSC1845FTA
AWR-099 Q2 2SC869-C o/c 512-KSC1845FTA
AWR-099 Q3 2SC945-A dc 512-KSC1845FTA
AWR-099 Q4 2SC945-A dc 512-KSC1845FTA
AWR-099 Q6 2SC945-A dischg 512-KSC2383OTA
AWR-099 Q9 2SC945-Q dar +13 512-KSC2383OTA
AWR-099 Q7 2SC1384-R relay drive 512-KSC2690AYS
AWR-099 Q8 2SD313-D pass +13 512-KSC2073TU
AWR-099 Q10 2SD313-D pass +34 512-KSC2073TU
AWR-099 Q11 2SC945-Q dar +34 512-KSC2383OTA
AWR-099 Q12 2SB507-D pass -38 512-KSA940TU
AWR-099 D1 1S1554 512-1N4148
AWR-099 D2 1S1554 512-1N4148
AWR-099 D3 1S1554 512-1N4148
AWR-099 D4 1S1554 512-1N4148
AWR-099 D5 1S1555 512-1N4148
AWR-099 D6 1S1555 512-1N4148
AWR-099 D7 1S1555 512-1N4148
AWR-099 D8 1S1554 512-1N4148
AWR-099 D9 1S1555 512-1n4004
AWR-099 D10 WZ-140 (Zener) 512-1N5244B
AWR-099 D12 WZ-140 (Zener) 512-1N5244B
AWR-099 D11 WZ-240 (Zener) 512-1N5252B
Power Supply Assembly
AWR-100 D1 1S1885 512-1n4004
AWR-100 D2 1S1886 512-1n4004
AWR-100 D3 1S1886 512-1n4004
AWR-100 D4 1S1886 512-1n4004
AWR-100 D5 1S1886 512-1n4004
AWR-100 D6 SR3AM-8 625-1N5404-E3
AWR-100 D7 SR3AM-8 625-1N5404-E3
AWR-100 D8 SR3AM-8 625-1N5404-E3
AWR-100 D9 SR3AM-8 625-1N5404-E3
Tuner, AF & Control Assembly
AWE-073 Q11 2SA725-G mic amp 512-KSA992FBU
AWE-073 Q12 2SC1344-D mic amp 512-KSC1845FTA
AWE-073 Q13 2SA733-Q muting 512-KSA992FBU
Amplifier Assembly
AWK-065 Q1 2SA725-G (2SA640-E) 512-KSA992FBU
AWK-065 Q2 2SA725-G (2SA640-E) 512-KSA992FBU
AWK-065 Q3 2SC1313-G 512-KSC1845FTA
AWK-065 Q4 2SA726-G (2SA640-E) 512-KSA992FBU
Insulator Pads
532-4170 pads
Relay
653-MY4-02DC24
Capacitors
Filters & Muting Assembly
AWM-094 c1 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWM-094 c2 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWM-094 c3 10 35v cea 10 50 647-UPW1H100MDD1TD
AWM-094 c5 100 35v cea 100 50 647-UPW1H101MPD
AWM-094 c7 1 25v csza 1 50 647-UKL1H010KDDANA
Tone Control Assembly
**AWG-046 C1 0.47 25v cssa 0.47 50 598-DSF050J474 ( OBSOLETE: replace with 871- B32529C474J )
**AWG-046 C2 0.47 25v cssa 0.47 50 598-DSF050J474 ( OBSOLETE: replace with 871- B32529C474J )
AWG-046 C3 100 6v cea 100 10 647-UPW1A101MDD
AWG-046 C4 100 6v cea 100 10 647-UPW1A101MDD
AWG-046 C7 220 35v cea 220 35 647-UPW1V221MPD
AWG-046 C8 220 35v cea 220 35 647-UPW1V221MPD
AWG-046 C9 4.7 25v ceanl 4.7 50 647-UKL1H4R7KDDANA
AWG-046 C10 4.7 25v ceanl 4.7 50 647-UKL1H4R7KDDANA
awh-046 c1 1 25v csza 1 50 647-UKL1H010KDDANA
awh-046 c2 1 25v csza 1 50 647-UKL1H010KDDANA
awh-046 c7 220 6v cea 220 10 647-UPW1A221MED
awh-046 c8 220 6v cea 220 10 647-UPW1A221MED
awh-046 c9 100 35v cea 100 50 647-UPW1H101MPD
awh-046 c10 100 35v cea 100 50 647-UPW1H101MPD
awh-046 c13 220 6v cea 220 10 647-UPW1A221MED
awh-046 c14 220 6v cea 220 10 647-UPW1A221MED
**AWR-099 C1 0.22 10v cssa 0.22 50 598-DSF050J224
(OBSOLETE : Replace with 871-B32529C1224J)
**AWR-099 C2 0.22 10v cssa 0.22 50 598-DSF050J224
AWR-099 C3 330 6v cea 330 10 647-UPW1A331MPD
AWR-099 C4 330 6v cea 330 10 647-UPW1A331MPD
AWR-099 C5 3.3 10v cea 3.3 50 647-UPW1H3R3MDD
AWR-099 C6 220 16v cea 220 35 647-UPW1V221MPD
AWR-099 C7 220 16v cea 220 35 647-UPW1V221MPD
AWR-099 C8 100 35v cea 100 50 647-UPW1H101MPD
AWR-099 C9 100 50v cea 100 50 647-UPW1H101MPD
AWR-099 C10 100 50v cea 100 50 647-UPW1H101MPD
AWR-099 C11 4.7 35v cea 4.7 50 647-UPW1H4R7MDD
AWR-099 C12 220 16v cea 220 35 647-UPW1V221MPD
AWR-099 C13 100 35v cea 100 50 647-UPW1H101MPD
AWR-099 C15 100 50v cea 100 50 647-UPW1H101MPD
AWR-099 C16 100 50v cea 100 50 647-UPW1H101MPD
AWR-099 C17 330 50v cea 330 50 647-UPW1H331MPD
AWR-099 C18 330 50v cea 330 50 647-UPW1H331MPD
AWR-100 C1 470 10v cea 470 16 647-UPW1E471MPD
**AWE-073 C27 0.47 50v cea 0.47 50 598-DSF050J474
(OBSOLETE: replace with 871- B32529C474J )
AWE-073 C41 100 16v cea 100 50 647-UPW1H101MPD
AWE-073 C42 220 16v cea 220 35 647-UPW1V221MPD
AWE-073 C45 4.7 16v csza 4.7 50 647-UKL1H4R7KDDANA
AWE-073 C46 1 25v csza 1 50 647-UKL1H010KDDANA
AWE-073 C47 3.3 10v csza 3.3 50 647-UKL1H3R3KDDANA
**AWE-073 C48 0.22 35v csza 0.22 50 598-DSF050J224
AWE-073 C54 220 6v cea 220 10 647-UPW1A221MED
AWE-073 C60 4.7 35v cea 4.7 50 647 -UPW1H4R7MDD
AWE-073 C61 47 6v cea 47 35 647-UPW1V470MED1TD
AWE-073 C62 220 16v cea 220 35 647-UPW1V221MPD
**AWE-073 C66 0.1 35v csza 0.1 50 598-DSF050J
(OBSOLETE : Replace with 871-B32529C1104J189)
AWE-073 C80 10 16v cea 10 50 647-UPW1H100MDD1TD
AWE-073 C81 10 16v cea 10 50 647-UPW1H100MDD1TD
AWE-073 C82 1 25v csza 1 50 647-UKL1H010KDDANA
AWE-073 C83 1 25v csza 1 50 647-UKL1H010KDDANA
AWE-073 C84 220 25v cea 220 35 647-UPW1V221MPD
AWE073 C85 220 25v cea 220 35 647-UPW1V221MPD
AWE-073 C86 4.7 16v ceanlnp 4.7 50 647-UKL1H4R7KDDANA
AWE-073 C88 100 6v cea 100 10 647-UPW1A101MDD
AWE-073 C89 100 6v cea 100 10 647-UPW1A101MDD
AWE-073 C98 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWE-073 C99 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWE-073 C102 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWE-073 C105 2.2 25v csza 2.2 50 647-UKL1H2R2MDAANA
AWE-073 C106 220 35v cea 220 35 647-UPW1V221MPD
AWE-073 C111 10 16v cea 10 50 647-UPW1H100MDD1TD
Amplifier Assembly
AWK-065 C3 100 10v cea 100 10 647-UPW1A101MDD
Main filter Caps
80-ALT22A153DE63
_________________________________________________________________________
BOM LIST ACTUAL QUANTITIES
647-UKL1H2R2MDAANA (6 )
647-UPW1H100MDD1TD ( 4 )
647-UPW1H101MPD ( 10 )
647-UKL1H010KDDANA ( 6 )
871- B32529C474J ( 3 ) ----- Replaces 598- DSF050J474
647-UPW1A101MDD ( 5 )
647-UPW1V221MPD ( 10 )
647-UKL1H4R7KDDANA ( 4 )
512-KSC2383YTA ( 2 )
512-KSC2690AYS ( 2 )
512-KSA1220AYS ( 2 )
512-1n4148 ( 10)
652-3352V-1-101LF ( 2 ) ------ Trim Pots
647-UPW1A221MED ( 5 )
512-KSC945CYTA or
512- KSC945CGBU ( 4 ) ----- Replaces 512-KSC1845FTA
512-KSC2383OTA ( 3 )
512-KSC2073TU ( 2 )
512-KSA940TU ( 1 )
512-1N5244B ( 2 )
512-1N5252B (1)
871-B32529C1224J ( 3 ) -----Replaces 598-DSF050J224
647-UPW1A331MPD ( 2 )
647-UPW1H3R3MDD ( 1 )
647-UPW1H4R7MDD ( 2 )
647-UPW1H331MPD ( 2 )
512-1n4004 ( 6 )
625-1N5404-E3 ( 4 )
647-UPW1E471MPD ( 1 )
512-KSA733CGBU ( 5 ) ----- A Substitute for 512-KSA992FBU
647-UKL1H3R3KDDANA ( 1 )
647-UPW1V470MED1TD ( 1 )
871- B32529C1104J189 ( 1 ) -----Replaces 598-DSF050J
532-4170 pads ( 4 ) -----Insulating Pads
653-MY4-02DC24 ( 1 )------ Relay
80-ALT22A153DE063 ( 2 ) ----- The Main Filter Caps 40mm Dia and Beefy pins
Amplifier Assembly
Insulator Pads
532-4170 pads
Relay
653-MY4-02DC24
Capacitors
Amplifier Assembly
Main filter Caps
80-ALT22A153DE63
512-1n4148 ( 10)
512-KSC945CYTA or
512-KSC2073TU ( 2 )
512-KSA940TU ( 1 )
512-1N5244B ( 2 )
512-1N5252B (1)
512-1n4004 ( 6 )
625-1N5404-E3 ( 4 )
