49erFaithful
New Member
Hi everyone,
I recently got a non-working Pioneer SX750 in a trade. I'm just starting to try and work on these things so please forgive some of my ignorance or lack of technical terms.
The unit wouldn't power on at all when I got it. No relay clicks or anything. I took the bottom panel off and confirmed continuity in all of the fuses. However, I did notice that I I wasn't getting full voltage to the main fuse. In fact, I'm not getting any voltage reading on the two posts on either side of the main fuse.
Where the power cord comes into the receiver, the hot line and ground split and are soldered onto two posts. I thought that the old cord may have been the problem, so I replaced it, but I'm still getting the same readings. I'm getting about 20 volts on the hot line post, but that's it. And it obviously isn't enough to get the unit to power on.
I'll post some pictures to show you what I'm working with. Any advice would be great. Not sure what to check next.
