Pioneer SX-838 voltage problems???
Discussion in 'Pioneer Audio' started by Tomcow, Oct 6, 2018.
  1. Tomcow
    Tomcow Active Member
    116
    Pioneer SX-838 powers on but no relay.Getting strange voltmeter readings on both power supply board and protection board.PS,pin 1,-21mv,pin 2,plus 20mv,pin 3,plus 20mv,pins 4 and 5,plus and - 41V,pin 6,0mv,pin 7,-43V,pins 8 and 9,-155mv,pins 10 and 11,plus 10V,pins 12 and 13,plus 14V,pin 14,plus 12.7V,pins 15 and 16,0mv,pin 17,plus 49V,pins 18 and 19,minus 187mv,pin 20,0mv,pin 21,7V,pin 22,6mv,pin 23,plus6.2mv,pin 24,-6.3mv
  2. Tomcow
    116
    Protection Board:pin 1,plus 10V,pin 2,-156mv,pin 3,-12.8V,pin 4,0mv,pin 5 and 6,plus 10V,pins 7 and 8,-12.9V,pin 9,plus 3.8V,pins 10 and 11,plus 14.7V,pin 12,plus 7.4V,(AC)
  3. Watthour
    A little clearer format (then I'll try to digest them):
    Power Supply:
    Pin 1, -21mV,
    Pin 2, + 20mV,
    Pin 3, + 20mV,
    Pins 4 and 5, ±41V,
    Pin 6, 0mV,
    Pin 7, -43V,
    Pins 8 and 9, -155mV,
    Pins 10 and 11, + 10V,
    Pins 12 and 13, + 14V,
    Pin 14, + 12.7V,
    Pins 15 and 16, 0mV,
    Pin 17, + 49V,
    Pins 18 and 19, minus 187mV,
    Pin 20, 0mV,
    Pin 21, 7V,
    Pin 22, 6mV,
    Pin 23, +6.2mV,
    Pin 24, -6.3mV
    Protection Board:
    Pin 1, + 10V,
    Pin 2, -156mV,
    Pin 3, -12.8V,
    Pin 4, 0mV,
    Pin 5 and 6, + 10V,
    Pins 7 and 8, -12.9V,
    Pin 9, + 3.8V,
    Pins 10 and 11, + 14.7V,
  4. Watthour
  5. Watthour
    Check the voltages on the PS board Pins 1, 2, 3, 18, 19, 22, 23, & 24 on an AC volts scale.
  6. Tomcow
    116
    Yes it is and those readings on the various pins were taken this morning,Regards, Tom
  7. Tomcow
    116
  8. Tomcow
    116
    Ok.pin 1,37.5V,pin 2,31.7V,pin3,31.7V,pin 18,38.9V,pin 19,38.9V,pin 22,7.5V,pin 23,7.7V,pin24,6V all read with voltmeter on AC.
  9. Watthour
    So the updated measurements are:
    Power Supply:
    Pin 1, 37.5VAC,
    Pin 2, 31.7VAC,
    Pin 3, 31.7VAC,
    Pins 4 and 5, ±41V,
    Pin 6, 0mV,
    Pin 7, -43V,
    Pin 14, + 12.7V,
    Pin 17, + 49V,
    Pin 18, 38.9VAC,
    Pin 19, 38.9VAC,
    Pin 20, 0mV,
    Pin 21, 7V,
    Pin 22, 7.5VAC,
    Pin 23, 7.7VAC,
    Pin 24, 6VAC
    Protection Board:
    Pin 1, + 10V,
    Pin 2, -156mV,
    Pin 3, -12.8V,
    Pin 4, 0mV,
    Pin 5 and 6, + 10V,
    Pin 9, + 3.8V,
  10. Tomcow
    116
    Yes.All the readings are taken in dc,except the ones you told me to check in ac.Regards,Tom
  11. Watthour
    Does the dual diode bridge D6 check out good?
  12. Tomcow
    116
    Is that the little square black box with the 2 arrows on top pointing at each other?3 pins going into the board? What should it read?
  13. Watthour
    That's the square box. The two arrows each represent one diode. Those can be tested for resistance in the forward/reverse direction using the center (common) lead as a reference for each diode. The resistances should be around 500Ω in the forward direction and at least 1,500Ω in the reverse direction for each half.
  14. Tomcow
    116
    With my ohm meter,I get 8,000 ohm each way with the black probe on the middle pin.
  15. Tomcow
    116
    Til it went to K ohms,the meter was jumping all the place,then to OL
  16. avionic
    46,508
    Fort Dodge, Iowa
    Looks bad to me.
  17. Tomcow
    116
    Is this the SR3am-8 rectifier?It could certainly cause all the voltage problems on the PS board,I would think.Could it be replaced with a 512-1N5404?
  18. avionic
    46,508
    Fort Dodge, Iowa
  19. Tomcow
    116
    All the diodes I see now just have 2 ends with the band on one end
  20. avionic
    46,508
    Fort Dodge, Iowa
    Yes you would need two of them
