Re: tone controls not working - there is a switch that turns OFF the tone controls and lets the audio go straight through. In the middle of the tone control knob and lever group.
Please don't use that reporting format again, it causes eyestrain, neck strain, repeated errors in checking, discourages engagement in the discussion, and takes me just too much time to sort out for me or anyone else.
(AWH-050) numbers 1-15
pin 1 -51.7v DC
pin 2 -51.7v DC
pin 3 0v DC
pin 4 -0.9v DC
pin 5 -0.9v DC
pin 6 0.00v DC
pin 7 52.1v DC
pin 8 52.2v DC
pin 9 0.00v DC
pin 10 15.8v DC
pin 11 15.8v DC
pin 12 15.7v DC
pin 13 15.7v DC
pin 14 51.0v DC
pin 15 -51.0v DC
(-51.7 -51.7 0 -.9 -.9 0 52.1 52.2 0 15.8 15.8 15.7 15.7 51.0 -51.0).
For pins 16 - 30 (-51.6 -51.5 0 -.9 -.9 0 52.4 52.4 0 15.0 15.0 15.0 15.0 51.1 -51.2)
For the Protection Board (AWM-062) pins 1-12 I got:
(15.89 -13.21 15.15 0 15.87 15.84 15.11 15.14 -.99 -.99 -.99 0).
pin 1 15.89v DC bad
pin 2 -13.21v DC good
pin 3 15.15v DC
pin 4 0.00v DC
pin 5 15.87v DC
pin 6 15.84v DC
pin 7 15.11v DC
pin 8 15.14v DC
pin 9 -0.99v DC
pin 10 -0.99v DC
pin 11 -0.99v DC
pin 12 0.00v DC
AWR-101 board, these are regulated voltages, unless otherwise indicated. the voltage readings are ground referenced:
pins 2 & 3 +5.4v dc regulated
pins 4 & 5 +13.9v dc regulated
pins 6 & 7 +51.5 v dc regulated this is ok on yours
pins 8, 9 & 10 +36.5v dc regulated seems to be missing
pin 11 +28v dc regulated
pin 13 -13.5v dc regulated this is ok on yours
pin 14 -51.5v dc regulated this is ok on yours
pin 15 -19v dc regulated
pin 17 - 49.5v dc raw unregulated dc to the output transistor circuits,
pin 18 49.5v dc raw unregulated dc to the output transistor circuits
AWM-062 protection board
pin 11 +36.5v dc
pin 2 -13.6v dc
pin 12 7.5v AC
pin 1 audio input, good would be dc millivolts, bad can go up to over 30v
pin 3 audio input, good would be dc millivolts, bad can go up to over 30v
pin 5 audio over-current protection input, good would be dc millivolts, bad can go up to over 30v
pin 6 audio over-current protection input, good would be dc millivolts, bad can go up to over 30v
pin 7 audio over-current protection input, good would be dc millivolts, bad can go up to over 30v
pin 8 audio over-current protection input, good would be dc millivolts, bad can go up to over 30v
loosing too much time unraveling and posting this - rebuild your power supply FIRST. At LEAST Q5 is blown, it is undersized for it's tasks, and my recommended replacement for it IS more robust. This is a common failure. The lists are published elsewhere in this forum.
