Pioneer SX-950 wont come out of protection
Discussion in 'Pioneer Audio' started by CavScout, Jul 2, 2018.
  1. CavScout
    CavScout Well-Known Member
    600
    Medicine Hat
    Hi folks
    I am hoping some of the experts out there can assist me with a problem I am having.
    I just bought an SX-950 and the unit will not come out of protection at all.
    I hooked up a DBT and there are no shorts.
    I would like to start with the simple stuff so.......
    Is it possible if I remove it and deox it that it will work or ???
    Any assistance is greatly appreciated
    Thanks
  2. petehall347
    28,257
    uk.. the middle bit
    check voltages at the protect circuits pins .
    slimecity likes this.
  3. CavScout
    600
    Medicine Hat
    I have a basic Fluke multimeter. What do I set it to?
    Do I put the black to the stereo frame as ground?
    What readings am I looking for?
    Thanks for your help
  4. slimecity
    slimecity Super Member
    3,156
    New Zealand
    You will need to find & download the service manual for this model.
    Set the meter to DC mV.
    You will need to measure the DC mV (very carefully) at the points petehall refers to - these will measure the DC offset at the amount going into the speaker protect relay side.
  5. w1jim
    w1jim I can fix it but good... Subscriber
    7,717
    Boston western 'burbs
    Go to hifiengine.com and download the service manual.
    Read it, check the dc offset and bias as described therein.
  6. 1MEGΩ
    1MEGΩ Active Member
    234
    Mamou, Louisiana
  7. 1MEGΩ
    1MEGΩ Active Member
    234
    Mamou, Louisiana
    Power Amplifier voltages on Page 76, Protection Circuit voltages on page 81, not numbered, and Power Supply voltages on page 84, not numbered. Just scroll down the pages to find them.
  8. CavScout
    600
    Medicine Hat
    Thanks folks.
    I am not very good at reading elec schematics at all.
    But I do see 8 voltages referred to on that page .
    There are 4 pins that are bridged and 2 that are single.
    The voltages that I see on that page are
    36.5
    1.0
    7.5
    13.5
    5.1
    0.6
    0.6
    0.7
    So there are references to 8 voltages but 10 pins (including the bridges.......and I would assume each bridge would have equal voltage reading)
    Also, silly question guys but... I hold the red to the test point and clip the black to the frame of the unit right ?
  9. CavScout
    600
    Medicine Hat
    Should the unit be on or off while taking these readings?
  10. w1jim
    7,717
    That's an easy one - ON.
    But be careful not to short out any pins while taking measurements.
    Your ground lead goes to the chassis.
  11. CavScout
    600
    Medicine Hat
    So when I tested it with the unit off the readings were falling fast until zero.
    I guess this is because the caps behind these readings are dumping to the frame?
  12. CavScout
    600
    Medicine Hat
    The Mv AC readings that I got were
    From the 2 orange wire connections
    67.5
    377.0 ( very erratic)
    From the 2 yellow wire connections
    71.2
    97.1
    From the grey wire (to a single pin)
    10.3
    From the black/white wire (to a single pin)
    0.5
  13. Markoneswift
    Markoneswift Quartz locked n ready to rock
    3,519
    Aotearoa New Zealand
    Yeah you need the unit on for testing voltage and usually off for resistance etc
  14. Markoneswift
    3,519
    Hopefully those were mV DC :)
  15. Markoneswift
    3,519
    And I'm thinking you've got a whole lot of DC hitting that protection circuit.
  16. Markoneswift
    3,519
    I might have one of these to work on myself soon so .....:lurk:
  17. CavScout
    600
    Medicine Hat
    I followed the previous Instructions in this thread and set it to MV which was AC.
    So for DC, i set it to V and the readings were
    15.94
    15.11
    .005
    .005
    1.21
    1.21
  18. CavScout
    600
    Medicine Hat
    Here is where I have it set now
  19. Watthour
    The wire wrap connection pins have numbers assigned to them. It would help to know what voltages are a which pins, since colors are not always consistent. For example, Pins 1 should normally be at or below 0.010VD, Pin 2 should be around 13V (-), Pin 3 should be at or below 0.010VDC, etc.
  20. CavScout
    600
    Medicine Hat
    Watthour those are not far from what I measured
    15.94
    15.11
    .005
    .005
