Yes, I replaced one a few months ago, a big PITA. Took me about 2 hours to do. As I recall, I did remove front panel, took the tuner cord off one of the rollers so there is slack. I then carefully and gently moved the pointer down at an angle until I could slide it out from under the dial. Doing that and reverse process to get it back in there was the worst. that pointer will flex a bit, but be very careful not to break it. Put an LED light in there so that it never has to be done again.
