Texas42
Well-Known Member
I haven't used my SA-8100, TX-8100 combo much the past few months so powered them up today only to find the left channel is barely audible. I traced the problem down to the tuner instead of the amp as the reverse stereo and mono work fine with the amp. Also the CD player through the Auxillary input and another tuner worked fine as well. What type of things should I look for in fixing a tuner where one channel is almost completely out? I going to take it apart in a bit and see if I can locate a loose solder or burn out part. Just wondering if this is a common problem that is easily fixable or it is a sign of a major issue. Thanks for any inputs. Wasn't sure where to post this; Pioneer forum, Tuner forum, etc...
