Pioneer TX-9500 troubleshooting
Discussion in 'Tuners' started by brillcat, Feb 26, 2016.
  1. brillcat
    brillcat Active Member
    120
    Just picked up a very clean example. cosmetically that is. It powers on but I get no audio output when tuning the dial, from either the fixed or variable RCA jacks. I have checked the obvious, starting with hooking up a known good tuner. So the cabling and amp are not suspect. The fuse on the back is not blown, which I assume would leave me with a totally dead unit. Any suggestions on where to start? I am handy with screwdrivers and Deoxit and have a multimeter. Oh and the meters... No movement at all when I turn the tuning knob. The signal strength meter is zeroed and the tuning meter is centered.
  2. kcvet
    kcvet Active Member
    226
    Missouri
    a print would be good. start with the power supply. good suspect for dead puppies
  3. RxDx
    RxDx Speaker collector Subscriber
    1,281
    Virginia, the colonies
  4. dr*audio
    18,949
    Cleveland, Ohio
  5. brillcat
    120
    Great thread dr*audio. The tuning section is covered and so it looks super clean inside. Still I will get some compressed air and fader lube for the contact points (the grease looks pretty dry). When you said "power supply voltages" did you mean the power to the tuning section?
  6. dr*audio
    18,949
    Cleveland, Ohio
    You will need non residue contact cleaner for the contact points.
    Yes, check the power supply voltages to the tuner front end and the IF section.
  7. brillcat
    120
    I found some CRC non-residue electrical cleaner locally but my understanding is I then need to lube the contact area with faderlube, yes? ( I need to order that from Amazon.)
  8. petehall347
    28,400
    uk.. the middle bit
    have you tried am and fm ?
    muting off .
  9. dr*audio
    18,949
    Cleveland, Ohio
    Yes, Faderlube, just a drop or 2 on each contact.
  10. brillcat
    120
    Update: I cleaned the tuning cap as suggested, which looked super clean to begin with... but still no FM signal. The tuner section was not getting power and this was as far as I could take it with my limited skills. Fortunately a neighborhood audio buff suggested Geoff Bourquin at Northwest Electronics in Sequim, about 30 minutes away. He found the problem right away, I believe he said a cooked part (transistor?) and replaced it, also added a small heat sink to help dissipate heat. He checked out the tuner and ran it all day, no other problems. Very reasonable charge and I got it back today, hooked it all up and it sounds fantastic. I cannot tell you how good it is to have someone with tech skills nearby on the Olympic Peninsula -- thanks Geoff!
  11. rcs16
    4,309
    Baldwin, Ontario, Canada
    Sounds like a power supply failure, good to hear you are happy.
  12. ChuckW
    ChuckW New Member
    13
    Wheeling W.V.
    I have a Pioneer TX 9500 that works but I get random crackling noise only when set on fm stereo and mono. Not on AM.
  13. dr*audio
    18,949
    Cleveland, Ohio
    Could be local interference.
  14. ChuckW
    ChuckW New Member
    13
    Wheeling W.V.
    It sounds like a bad connection but only on fm, Am and test tone are fine. I will try again later to see if it persists.
  15. dr*audio
    18,949
    Cleveland, Ohio
    Both channels or just one?
  16. ChuckW
    ChuckW New Member
    13
    Wheeling W.V.
    Same on both channels. Could it be dirty tuning capacitor?
  17. dr*audio
    18,949
    Cleveland, Ohio
    First clean the selector switch. Then clean the tuning cap with a non residue contact cleaner as per instructions in the above thread.
