Halisson
Member
Hello guys. I am from Brazil and I maintain some receivers but the Pionner SX1980 is not very common equipment here. I searched for a lot of research before creating this topic.
Started with the 2SK34 with problems what solved with the tip of substitution (markthefixer) and some more repairs in the source and everything is with the tensions in order.
However, I do not have AM tuning (this does not interest me), but the FM has tuning but does not indicate anything and the three light fine tuning, stereo, lock function lights do not work, but I have FM tuning and it does not change with FM in mono or stereo and Fm Muting.
The voltages of the ICs are:
pa1001
1 - 2.0
2 - 2.0
3 - 2.0
4 -
5 -
6 - 5.7
7 - 5.7
8 - 5.7
9 - 5.7
10 - 5.7
11 - 12v ( wrong tension compare service manual )
12 - 4.09
13 -
14 -
15 - 5.6
16 - 4.2
pa3001
1 - 13
2 - 3.0
3 - 5.10
4 - 9.68
5 - 9.68
6 - 11.9
7 - 0
8 - 2.0
9 - 0.8
10 - 2.3
11 - 2.3
12 - 2.1
13 - 2.1
14 - 2.1
15 - 3.7
16 - 0.3
I still have not changed the capacitors and it was only a few hours ago than some kind of diagnosis. I note on the oscilloscope some kind of voltage variation on pin 1 and pin 2 on the PA3001 when moving the tuner.
I also tested with an external antenna, not changing the problem.
Thanks for any help.
pa1001
1 - 2.0
2 - 2.0
3 - 2.0
4 -
5 -
6 - 5.7
7 - 5.7
8 - 5.7
9 - 5.7
10 - 5.7
12 - 4.09
13 -
14 -
15 - 5.6
16 - 4.2
pa3001
1 - 13
2 - 3.0
3 - 5.10
4 - 9.68
5 - 9.68
6 - 11.9
7 - 0
8 - 2.0
9 - 0.8
10 - 2.3
11 - 2.3
12 - 2.1
13 - 2.1
14 - 2.1
15 - 3.7
16 - 0.3
